fuel pin help ?
Old Jan 1, 2013 | 07:40 PM
1993cummins's Avatar
Default fuel pin help ?
so i have a bone stock 1993 dodge cummins , besides the suspension
i dont have aftermarket gauges , but all my stock ones work.
do i need aftermarket gauges to get a dennyt 1 fuel pin ? ,
and whats the difference between denny 1 and 2 ? . thanks guys
Old Jan 1, 2013 | 09:03 PM
BIGREDGOAT's Avatar
Yes!!! Any thong that you do to modify the fuel system you need to be able to monitor your get at least....
Sent from my C771 using Tapatalk 2
Old Jan 4, 2013 | 10:08 AM
firstgenfreak93's Avatar
Gauges first... they r most important. The difference in stage one and stage two is about 20 hp. You can get free hp by turning up the fuel to your pump for free. Do that first.
Old Jan 4, 2013 | 05:50 PM
Do i need gauges ? , I am tight on money and before i ordered the pin i didnt think it would need gauges , if i absoulutley need them what are the gauges i need ?
Old Jan 4, 2013 | 06:13 PM
BIGREDGOAT's Avatar
Well, pyrometer. That way you can monitor your exhaust gas temperature. If you can spare the coin, a boost, monitors turbo psi, and fuel pressure, which monitors your fuel pressure going to the ip
Old Jan 4, 2013 | 06:41 PM
okay , i guess i wont be driving for a while until i can afford gauges , what do you recomend for pyrometre ? , any half decent deals out there ?
Old Jan 4, 2013 | 07:05 PM
BIGREDGOAT's Avatar
Isspro and try our vendors bud! And if you do drive it, becareful... the cost to rebuild it yourself is 2500+
Old Jan 4, 2013 | 08:29 PM
thanks for the help man ! , i will just install the pin when i get the pyro gauge so i can drive in the meantime !!!!!
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
robbyS
Apr 16, 2015 02:22 PM
359ci12v
Apr 9, 2015 08:24 AM
moneypitk5
Feb 12, 2015 11:01 AM
