PureFlow and FRRP
Old Dec 31, 2012 | 09:12 PM
99coalroller24V's Avatar
Default PureFlow and FRRP
I Have been seeing people complaining that the ADs and Raptor pumps from pureflow are junk now days. Is this as bad as people are making it. The only fuel mod i have on my truck is a edge drag comp (which i dont turn up since i have no LP) and plan to add 100 hp injector nozzles on top of that after i get a pump. Where do i start..i know the FRRP would be the pump for me but with all these complaints about the motors dying and not holding pressure is making me wonder. Please Help with some input on this
Old Dec 31, 2012 | 09:33 PM
mysterync's Avatar
I had quite a bit of trouble with the airdog. The Fass direct replacement pump works very well! If you ever have plans of bigger power you should plan for it when considering your purchase of a lift pump, maybe consider 95gph or something similar?
Old Dec 31, 2012 | 09:41 PM
I looked into the FASS HPFP pump but its $120 more than the Raptor FRRP and right now starting out in college as a freshy i need to stick with whatever will get me by until i get a degree and job.
Ive heard of a Holley Blue or Black Fuel Pump?
Old Dec 31, 2012 | 11:05 PM
mysterync's Avatar
A blue pump would be ok if you stretched the spring a bit. I honestly think the blue pump would last longer than the raptor. But you may never have a issue with the raptor, it may live forever but God help you if it ever needs a warranty replacement.
Old Dec 31, 2012 | 11:12 PM
I seen where guy said the Holley Blue blew his VP44 up and its not a diesel pump. Ive also heard that the Holley Black has better seals that is diesel resistant??
Old Jan 1, 2013 | 12:18 AM
Check out the DTT Assassin
Luke
Old Jan 1, 2013 | 07:50 AM
mysterync's Avatar
Originally Posted by DB Admin
Good to have you guys here , And thanks for the suggestions ,
Also dont mind the Visual looks Im still editing the colors ect..
Also this will be set up for the DMD,PSDand tdi guys as well .
Not many forum last too long like that but I think we can pull it off
DM
We've used them for years with the customers unwilling to spend money on anything else. With a gauge you wilk be just fine. Life span of 2 or 3 years?
