Odometer Repair Not Working
Old Dec 31, 2012 | 04:40 PM
dodgedually91's Avatar
Default Odometer Repair Not Working
Hi, I recently replaced both gears in my odometer trying to fix it. I also tried replacing all twelve bulbs in the instrument cluster. By the way, don't try the Napa or Kragen replacement bulbs because the plastic base won't screw into the cluster. After putting everything back together, I took it for a drive and got it to add a mile to the odometer and 9 tenths to the trip odometer. After that both stopped turning. I am wondering what would cause this. Could the gear be misaligned? I also put three drops of super glue on the larger gear but no lubricant which I guess could cause a problem. Thanks for any ideas.
Old Jan 1, 2013 | 09:05 PM
Today I took it apart and saw that a piece of blue plastic from the old gear jammed the new one. With a very small screw driver I cleaned all of the blue plastic out of the three pegs that hold the large gear on and then shot both gears with silicone. This seems to have worked and the odometer is turning now.
Old Jan 5, 2013 | 03:49 AM
Dodge9159's Avatar
Where did you get the gears to fix it? My odometer and speedometer quit working.
Old Jan 5, 2013 | 04:35 PM
I got the gears from Odometer Repair-Chrysler Odometer Gear-Speedometer Gear
However, your issue seems more like the vss because both the odometer and speedometer stopped working. My truck's small gear was blown to bits but the speedometer has always worked.
Old Jan 6, 2013 | 06:57 AM
Dodge9159's Avatar
Well my odometer quit about 2 yrs ago and my speedometer just stopped this pass summer. Idk though
Old Jan 6, 2013 | 07:21 PM
Hmmm. Well I guess the odometer gears are the cheapest place to start anyway. Diesel Truck Resource has a fairly thorough article about replacing the gears on their wiki. Its not hard just be patient, especially when trying to put on the new gear.
Cavnar
6.0L Performance
Apr 7, 2015 10:35 PM
Low_Life_Style
16
Nov 29, 2014 06:28 PM
wyoranch
Oct 28, 2014 08:23 AM
hemiheath
Oct 15, 2014 11:49 AM
jcottonoir
Oct 7, 2014 08:04 AM
