no low range
Old Dec 31, 2012 | 10:04 AM
94cummins12v's Avatar
Default no low range
04 ford f250 4x4 the 4x4 works but when i put it in low range the indicator light doesnt come on and i dont notice any gear reduction over the high range 4x4 any thoughts or ideas to why this would be?
Old Dec 31, 2012 | 10:09 AM
HeavyAssault's Avatar
Truck needs to be in neutral and foot on the brake pedal. You didn't mention your procedure in your OP.
Old Dec 31, 2012 | 10:52 AM
ok ill try it again today i think i tried that but ill try it again and check in later
Old Dec 31, 2012 | 12:02 PM
Mdub707's Avatar
Exactly what HA said. Put it in 4x4 like normal, come to a stop, put it in neutral, click over to 4x4 low, then back to drive, it should go in. Taking it out you must follow the same procedure.
Old Jan 6, 2013 | 03:13 PM
ok i got it figured out i needed to be stepping on the brake not just being in nuetral thanks
Old Jan 6, 2013 | 04:52 PM
Yep...it's not uncommon for either the neutral or brake part to be skipped.
corksil
Aug 2, 2015 10:19 PM
soco
Jul 27, 2015 06:06 PM
robbyS
Apr 16, 2015 02:22 PM
Feb 23, 2015 06:20 PM
