rebuild 727 vs getrag swap
Old Dec 31, 2012 | 08:23 AM
sootman's Avatar
Default rebuild 727 vs getrag swap
In the past week my battery exploded, the plastic piece on the throttle linkage broke and left me stranded 20miles from home at 3a.m., and finally 3rd gear is all but gone in the tranny. Ive been pondering whether to just have the 727 gone thru, put a converter and manual valve body in it, or swap in a getrag. What are y'alls opinion? I haven't decided if the truck is worth keeping after everything that has went wrong and is going wrong. Just looking for some advice.
Old Dec 31, 2012 | 12:03 PM
montepig72's Avatar
Keep the truck! The Getrag swap would be cool to get you overdrive, but would be labor intensive. In addition to all of the obvious changes you would have to make, I'm pretty sure you would need a t-case that came behind the Getrag. I'm pretty sure your 727 has a 23 spline output where the Getrag has a 29 spline. I think 29 spline NP205's go for pretty big $ because there hard to come by.
Old Dec 31, 2012 | 04:50 PM
sootman's Avatar
I think im gonna rebuild the 727. I found a hughes torque converter with a 1200rpm stall. Any body used one of their torque converters? Also thinking about a tci maximizer rebuild kit.
Old Dec 31, 2012 | 05:59 PM
turbo2332's Avatar
1200 is WAY TO LOW!!!!!!!!!!!!!! if i had to do it again i would have went higher than 1700 with mine. stock stall is around 2200 look into a 1900-2000 stall.
Old Dec 31, 2012 | 06:20 PM
sootman's Avatar
Im looking for the best fuel economy.
Old Dec 31, 2012 | 06:37 PM
turbo2332's Avatar
please do not get a converter built with a stall lower than 1700. you will not be able to put your truck in drive due to it stalling. mine stalls unless it warms up for about 20 min in the driveway when temps are below 30*. it will absolutly SLAM into drive and park which will tear up your trans and differentals. you do not want to do this
Old Dec 31, 2012 | 07:09 PM
sootman's Avatar
The truck already slams into gear. Well i found a hughes with 1800 stall. I guess ill go with that.
ReckONE
Diesel Engine Conversions
Feb 25, 2015 09:41 AM
metal_miner
Dec 23, 2014 11:40 PM
CumminsMan2.0
Dec 11, 2014 04:57 AM
dutchsupreme
Dec 10, 2014 12:34 PM
Jgloveracob
Nov 16, 2014 07:27 AM
