Get rid of blocks
I think what you would have to do is measure the block, and order a lift spring with that much extra lift. The perch on the axle already has the hole for the center pin so that shouldn't change, the spring should sit right on the existing perch without the block.
Would any spring shop be able to do this or do you know of any websites?
Here's one company that I know of that make pretty much whatever you can think of. Carrier spring makes stuff for heavy duty trucks, so I think they would be reputable.
Custom Suspension
Custom Suspension
Any idea what the smallest lift i could tuck 37's under? I'm reading from 4 inch lift to needing the 8 inch to fit them depending on the websites. I'm torn I love the look of it lifted up high but being in the military I need it somewhat usable for moving my stuff around all the time.
Dunno what kinda lift you need for those old dogs like yours. My 08 would clear 37's with a 3-4 inch lift, I suspect the new 12 will be the same. 37's are big for street use...
Ch
Sent using XT912 M
Ch
Sent using XT912 M
perk7089
Nov 5, 2014 06:41 PM
