my first diesel!!! finally
Old Dec 29, 2012 | 09:50 PM
Hoytshooter's Avatar
Default my first diesel!!! finally
Hi guys I just bought my first diesel and am very green to all of this I have been boggin for years but was finally able to save up and got a
98 2500 24v
It has a
-southbend Clutch
-62mm Turbo
-125 or 150 edge jammer injectors (Guy I bought it from forgot which ones he has 3 other Cummings)
-edge comp 1-5 settings
-smarty S-03 1-8 settings
-ladder bars
-holly auxiliary pump
I am very new to this so have any of you had this programer stack? My exhaust temps are about 7 at 60mph. But when I go to pass they jump right to 10-12 how can I keep my temps down is that normal? Any good preventative maintenance I can do any info would be greatly appreciated
I have Smarty set on 4 and edge on 1x1 for daily driving
What is normal amount of boost for 62mm Turbo.
Last edited by Hoytshooter; Dec 29, 2012 at 09:50 PM. Reason: Automerged Doublepost
Old Dec 29, 2012 | 10:01 PM
holset cummins's Avatar
to keep you egts down, i would get a water methanol injection kit. snow performance makes a good kit but there are different ones out there.
Old Dec 29, 2012 | 10:06 PM
RAW's Avatar
RAW
1000-1200 while passing is just fine. Exceeding 1350-1400 is getting into danger.
A 62 with the fuel to spool it should get into 45-50 psi range. Boost psi all depends on fuel and restriction of air flow.
Old Dec 29, 2012 | 10:07 PM
RAW's Avatar
RAW
Congrats on the purchase by the way!
Old Dec 29, 2012 | 10:13 PM
Cummings?
Luke
Old Dec 29, 2012 | 10:24 PM
Bryce's Avatar
In case you didn't already know, don't run your smarty on the odd number tunes with your edge comp.
Old Dec 29, 2012 | 10:25 PM
Thanks ! I just don't want to f it up ... I feel I got a good deal I paid 7500 it has 188xxx miles body 90% rust free. Is there any good sites or threads u recommend... I have alot to learn but everything seems simple just got to know correct settings and tricks
Old Dec 29, 2012 | 10:27 PM
Bryce's Avatar
Cummins. You will catch a lot of flak for spelling it cummings
Old Dec 29, 2012 | 10:32 PM
RAW's Avatar
RAW
Ignore those that get pissy about spelling Cummins with a g in it. Most the time they have a half dozen spelling errors in their post harassing you.
Lots of good information on here. Use the search bar on the top and off you can't find what your looking for, just ask.
Sounds like a good deal. Jammers are hit and miss. They are known for being hot and Smokey.
Old Dec 29, 2012 | 10:39 PM
My auto spell is to blame for that ...
