Check engine light??? Got me baffled
Old Dec 27, 2012 | 06:10 PM
nwright002's Avatar
Default Check engine light??? Got me baffled
It is about 30 degrees here in ohio. So I let my truck run for about 5 minutes before i took off. Got about 2 miles down the road and I was accelerating at about 50-75% throttle and the rpms bottomed out for a second and bounced all over the place and the check engine light came on.. Never noticed any hessitation or lack of throttle. Stopped at advance auto to have the code checked and there werent any codes so he reset it and the check engine light went out. Anyone have any ideas??
Old Dec 27, 2012 | 07:06 PM
RanchhandTCR's Avatar
You may want to go try someone else with a OBD Scanner and see if they have a good one not a cheapy. But You may have had just a hiccup with fuel dilivery or a lil bad fuel. Be nice to know what the code was.
Old Dec 27, 2012 | 07:39 PM
nwright002's Avatar
I would like to know the code as well.
Old Dec 27, 2012 | 08:25 PM
Is it running ok now or do you have issues that have arised?
Old Dec 28, 2012 | 04:54 AM
nwright002's Avatar
No problems at all as far as i can tell. runs fine no obvious leaks of any kind... like you said it might just have been a little hiccup... is the tachometer cable operated off the tranny? just thinking that it might have possibly skipped a tooth or something??
Old Dec 28, 2012 | 09:25 AM
No the tachnometer run of the cam and crank sensors. Then your spedo runs of a sensor in your rear diff and one in the tranny.
burndiesel
10
Feb 7, 2023 01:15 AM
Higgy
Jun 5, 2015 09:16 AM
gauge1325
May 3, 2015 01:33 PM
moneypitk5
Feb 12, 2015 11:01 AM
Rebel_redneck
Sep 29, 2014 11:05 AM
