warm start issue
Old Dec 27, 2012 | 12:15 PM
sootman's Avatar
Default warm start issue
Just recently started acting up. Left the truck sit outside for 20mins at oreillys. Started it and after 5shower secs it started idling way down like it was running out of fuel and then picked right back up. Got to work and tried starting it after 30mins. It did the same thing. I let it sit for almost 2hours and when i went to leave for lunch it loped for about 3secs, then ran rough and then idled up and ran fine. No smoke except black. Started doing this today and i havent done anything to the truck to make it do this. Going to drain the water out of the filter. After that i have no idea. Any ideas
Old Dec 31, 2012 | 05:01 PM
dodgedually91's Avatar
All I can think of is idle speed. Maybe the screw got loose with of miles of vibrations.
Or maybe injector failure. Try shooting a temp gun at the exhaust manifold ports and look for large temperature differences. Maybe someone else will help...
Old Jan 2, 2013 | 05:16 AM
sootman's Avatar
I took a heat gun to the exhaust manifold when i first got the truck. #6 was about 181 #5 was 195 #4 was 174 #1-3 were 155-160
Old Jan 2, 2013 | 01:49 PM
BIGREDGOAT's Avatar
Kinda sounds like an air intrusion, what about when the engine is cold?
Sent from my C771 using Tapatalk 2
Old Jan 2, 2013 | 05:01 PM
NadirPoint's Avatar
Tired VP. Just a guess.
Old Jan 2, 2013 | 07:11 PM
cumminskid92's Avatar
Do you still have the factory lift pump or an electric aftermarket pump
Cavnar
Sep 9, 2015 07:18 PM
Bigredpowerstroke
Aug 14, 2015 10:31 AM
tommyboy
May 6, 2015 04:50 PM
ronstop
Feb 26, 2015 09:48 AM
trab123
Feb 9, 2015 09:44 AM
