Loss Of Power
Old Mar 21, 2008 | 01:00 AM
94cummins12v's Avatar
Default Loss Of Power
i dont know if it is to serious or not but though i might bring it up when excellerating my truck looses power for about a secound and then gets it back. you can sorta tell by the feal of the truck but you can really tell in the boost guage and the wistle in the turbo. when it losses power for that short secound i loose about 3-4PSI of boost, any thoughts
Old Mar 21, 2008 | 01:11 AM
DB Admin's Avatar
Banned
Intercooler boots may be leaking , Check for loose clamps
Old Mar 21, 2008 | 04:38 AM
Uncle Bubba's Avatar
Any pattern here as to when it happens, under acceleration, cruising, when pulling any constants in the power loss would help tell more about it.
Old Mar 21, 2008 | 11:06 PM
you can only notice it accelerating empty and with a trailer, you can somewhat notic it when cruising with a trailer
well i checked the intercooler boots and there fine it olmost seems like when you are post heating your truck when the idle gets low for a secound then gets back to normal
Last edited by 94cummins12v; Mar 21, 2008 at 11:06 PM. Reason: Automerged Doublepost
Old Mar 22, 2008 | 05:01 AM
DB Admin's Avatar
Banned
Thats your Grid heater's Cycling , its normal
as for your loss in power under hard acceleration ,
Maybe your motor mounts , sometimes when the drivers side goes bad and you put a good load on her it torques the engine up on the drivers side and can pull your boot just about off off and when you let off it it comes down and the boot goes back on , Found this on a 94 12V
Its a long shot but has happened , Do you have Spring Clamps if not you should
Go over your boots and look for holes and signs of slipping , check around inner cooler too ,
Do you have your waste gate disabled ?
Old Mar 22, 2008 | 10:13 AM
DangerousDuramax's Avatar
Check your wastegate for leaks. If you're loosing 3-4 psi of boost and you boots are good and tight then the only other path of leakage is at the wastegate.
Old Mar 22, 2008 | 10:19 AM
well its not really under hard acceleration even if you go normal it still does it. i will double check all the boots today and let yal know, no i dont have spring clamps and when i get my new blue boots i will get some. yes my wastegate is closed off with a hose clamp for right now untile i get my new turbo upgrade next month then i will instal the boost elbow
Old Mar 22, 2008 | 10:25 AM
Run a small bead of silicone on the inside of the boot's when you reinstall them. We have this problem on the DMAX's and the silicone helps keep it sealed and holding tight. Check you hose for cracks. Depending on how long you have had it clamped off it could have started cracking and leaking air.
Old Mar 22, 2008 | 02:29 PM
DB Admin's Avatar
Banned
You need to cut your WG hose and stick a bolt in it and then clamp it
Old Mar 24, 2008 | 01:19 AM
well im just waiting on my new turbo with a boost elbow already in it, could me problem be coming from my governor spring
