Cant get truck to prime back?
Old Dec 27, 2012 | 12:09 PM
Bld0801's Avatar
Default Cant get truck to prime back?
I've got a 99 dodge 2500 and broke the numbrr three cylinder fuel line now i can't get the truck to prime back. I have broke all the lines loose and bled them truck still won't start any suggestions would be appreciated
Old Dec 27, 2012 | 12:15 PM
Farmboy 2.0's Avatar
Are you getting fuel to the pump? Are you having someone crank and then you tighten the lines as fuel as fuel squirts out.
Old Dec 27, 2012 | 01:10 PM
Bld0801's Avatar
Ya im cranking the valves back down while a buddy is turning the truck over and im getting fuel to all my lines
Old Dec 27, 2012 | 11:42 PM
73dartsport's Avatar
Sounds like you have another problem, I just removed and replaced my injection pump and i only had to crack 3 lines to get it to start. She ran rough for a couple min then smoothed right out.
Old Dec 28, 2012 | 02:27 PM
Bryce's Avatar
Check for codes. You can do the key trick (off, on, off, on, off, on. Leave on but dont start codes will show in the odometer window) but it would be best to use a scanner since some codes will not show with the key trick. Let us know what codes you get.
Old Dec 30, 2012 | 02:14 PM
cerickson's Avatar
And fill out your sig so we can help more
Old Dec 30, 2012 | 04:14 PM
thesmellycowboy's Avatar
When your starting with the lines cracked is fuel spraying or dripping out. My lift pump was weak when mine wouldn't prime right. I could fill the fuel filter housing but not start
Baradium
Mar 9, 2015 07:15 PM
clarthom
8
Mar 5, 2015 07:27 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
Dec 3, 2014 09:40 AM
Oct 14, 2014 08:40 AM
