Gov spring and fuel pin...truck wont start
Old Dec 26, 2012 | 09:10 PM
firstgenfreak93's Avatar
Default Gov spring and fuel pin...truck wont start
Hey guys, i put in a 3200 gov spring and a denny t stage 2 today. When i got finished, my truck wouldnt start. It is about 20 degrees outside right now soooo...anyway, it was hickuping like it needed fuel(obvious because i drained the pump before working on it) but because it is so cold out i hooked it up to a charger on high,start and then my starter selenoid would not engage my flywheel. Has this happend to anyone or do you guys have any suggestions? Please help, i would like to get it running by tomarrow.
Old Dec 26, 2012 | 09:57 PM
92betsy's Avatar
Did you index the throttle shaft properly? That is the most common problem after a spring swap.
Old Dec 26, 2012 | 10:22 PM
Do you mean lining it up with the second line on the assembly, if so then yes i did.
Old Dec 26, 2012 | 11:20 PM
92betsy's Avatar
I mean lining it up to stock.. 2nd line up on the right side[towards firewall] is what mine and what I understand IC motors are. Is yours IN or non-ic? 91 is non-ic 91.5 is ic. So not sure.
Old Dec 27, 2012 | 11:58 AM
mine is IC...91.5...i did line it up to stock so now what do you think the problem could be.
wannadrag
May 25, 2015 03:07 PM
bajahigh
8
Nov 27, 2014 11:48 AM
