Blue smoke
Old Dec 25, 2012 | 09:09 PM
Whitman41's Avatar
Default Blue smoke
Been having problems with injectors. I let my truck wrm up every morning for 15 minutes and it runs great especially with rev x last oil change. If I take off before truck is fully warmed poofs out blue smoke on me till motor finishes warm up and temp gauges rise. Is it the injectors most likely or the start of a new problem.
Old Dec 26, 2012 | 12:36 PM
c-tane's Avatar
I'm going to be watching this post... I installed a FICM programmer and upon start-up it's blowing blue smoke. I haven't heard back from the company I bought it from yet but, from what I've read blue smoke that hangs around at cold start is un-burnt fuel. I know that my problem is in the FICM (causing over fuel). I have seen turbo seals cause blue smoke too.
Old Dec 26, 2012 | 01:28 PM
Karls03's Avatar
Blue smoke is typically oil in the exhaust, SBCs with loose valve seals are known for this at cold start. Both times I had an injector stick open, first it was black (rich), then grey when it was stuck open DUMPING fuel into the cylinder. A choppy idle also accompanied the injector failure.
During cold starts, my 2003 would puff blue smoke, or make a cloud if it was cold enough. When I added RevX, the amount of blue smoke was GREATLY reduced. My thoughts are that the o-rings on the injectors are constricting at a different rate than the heads and the oil is allowed to pass by when cold. I could be wrong, but it explains the blue smoke.
Old Dec 26, 2012 | 06:38 PM
Whitman41's Avatar
That would make since then once everything heats up and expands it sealed Back up and stops
Old Dec 27, 2012 | 08:06 PM
Whitman41's Avatar
Noticed when its cold it blows the blue smoke when the turbo spools up
carid
Diesel Bombers Sponsors
Aug 13, 2015 05:49 AM
tim12valve
Jun 16, 2015 09:59 AM
gagemotors
Jun 9, 2015 04:24 AM
honda89
Dec 27, 2014 06:19 PM
lil red
Oct 10, 2014 09:03 AM
