no fire to injectors
Old Dec 25, 2012 | 08:34 PM
kennyjackson85's Avatar
Default no fire to injectors
I have a 1996 F-250 7.3 auto 4x4. My truck was running had a intake gasket go bad and started to get worse. i pulled it in to my shop to replace the gasket. easy enough job. deleted the ebpv while i had the turbo off. i noticed that one of the pigtails going to the valve cover was cracked so i went ahead and replaced both valve cover gaskets with new harnesses and pig tails. i was very careful matching the wires up double checked then triple checked. got the truck back together time to fire it up. thats a big no go checked the fuel pressure a little low so i replaced the fuel pressure reg on the back of the hpop still no start changed the cam sensor since it was the orignal one with 305 on the clock. still no start checked oil in pan and hpop both good bleed fuel lines no start the glow plugs are working. rpms move and oil pressuer come up on the gauges when cranking im keeping the truck on a trickel charge to keep the batterys up with all the cranking. i have not even been able to get her to puff out white smoke. i had a friend scan her with a snap on computer trouble code P1663 looked it up it fdcm i have checked visualy checked every wire back to the idm i have a feeling that could be bad but it was running and started better and faster then the 02 7.3 we have with 40k on the motor. could the idm just went bad like that ? i do not know any one with a idm that will work with my truck that i could swap out to rule that out. i have a few lead on a couple but with the holidays its hard to get up with people. also had a friend tell me if cracked the oil lines witch i did that it will not start untill i change my oil is that true? sound kinda silly to me. any help or advice would be great thanks. Kenny
by the way no chips or programmers all stock except for exhaust system
Last edited by kennyjackson85; Dec 25, 2012 at 08:34 PM. Reason: Automerged Doublepost
Renteria1217
19
Oct 13, 2015 01:36 AM
Militant83
For Sale
Mar 18, 2015 03:34 PM
klein444
Mar 8, 2015 11:42 AM
nate379
For Sale
Feb 15, 2015 03:23 PM
nate379
For Sale
Feb 9, 2015 08:27 PM
