Check Engine Light
Old Dec 25, 2012 | 03:46 PM
sjrvan's Avatar
Default Check Engine Light
I bought a 1999 Dodge Ram 2500 in April 2012 with 134k miles. The other day the check engine light came on and lost power, this sounds like a common problem. Changed fuel filter and the check engine light went off and it ran great. The next day started it and was letting it warm and I noticed a miss in the idle. Took off and it seemed fine, a couple of miles later the check engine light came back on and lost power. I could not get above 35 mph, also noticed that the lights were bright until I stepped on the throttle and they would go dim???
Old Dec 25, 2012 | 04:12 PM
RAW's Avatar
RAW
You'll need to check for codes. A simple code reader can be as cheap as $10, but can provide a significant amount of information. From there you can determine what the computer is telling you, and we can help you further from there.
Old Dec 25, 2012 | 06:08 PM
sjrvan's Avatar
Thanks for your response, I will check into one.
Old Dec 25, 2012 | 09:16 PM
daveO's Avatar
A lot of auto parts stores do free CEL code pulls as well, but a scanner is never a bad tool to have!
Old Dec 26, 2012 | 11:16 AM
sjrvan's Avatar
I bought a Actron AutoScanner OBD II Scan Tool CP9575 these are the codes that it showed P-606
P-234
P-123
P-382
P-121
What does this mean ????
PO-606 = Electronic Control Module Malfunction
PO-243 = Turbo boost limit exceeded
PO-123 = Acceleration Position Sensor Signal Voltage Too High
PO-382 = Intake Air Heater Relay 2 Control
PO-121 = Acceleration Position Sensor Volts Do Not Agree With Idle Valid Signal
Old Dec 26, 2012 | 08:54 PM
daveO's Avatar
Well P-0606 is a PCM/ECM Processor Fault. Usually a bad PCM. Did you get any freeze frame data?
Old Dec 29, 2012 | 07:57 AM
sjrvan's Avatar
Not yet, am planning on working on it this weekend. Work has been keeping me pretty busy.
PO-382 Intake Air Heater Relay 2 Control was on the freeze data.
Old Dec 29, 2012 | 09:31 PM
daveO's Avatar
I'll do some digging while at work tomorrow, but it sounds like you may be having a PCM issue. Try checking for damaged wires around the PCM.
Old Dec 30, 2012 | 03:35 AM
sjrvan's Avatar
I am going to check all the battery cables and make sure everything is clean and check all the grounds. Thanks Dave !!
Old Dec 30, 2012 | 08:49 PM
daveO's Avatar
