grid heat delete
Old Dec 24, 2012 | 10:48 AM
mudsling's Avatar
Default grid heat delete
what is the point of a grid heater delete?
Old Dec 24, 2012 | 11:03 AM
Mikeh1725's Avatar
Open up the intake side, and reduce the draining of your batteries during grid cycles
Before
After
Old Dec 24, 2012 | 04:16 PM
Bigg Redd's Avatar
These Cummins engines dont have glow plugs to aid cold starts. The grid heater will heat the incoming air to ease cold starts. The grid heater delete will eliminate the grid heater and allows about half a pound psi of additional boost, at higher RPMS. Unless you have mucho mucho horsepower, and youre looking for every ounce of additional boost, removing it is futile. It does not really restrict airflow during normal everyday driving or towing. There is some info online regarding airflow testing with and without the grid heater. The difference is really insignificant. Check it out for yourself and you be the judge. I still run mine, as do many others.
Old Dec 25, 2012 | 05:20 PM
mudsling's Avatar
ill be keeping it on right now then...rather have a easier cold start
Old Dec 26, 2012 | 10:30 AM
Mega Cummins's Avatar
I have the grid heater delete an haven't had any problems with it starting on a cold day. So far the coldest it has been was 17 degrees Fahrenheit though.
Old Dec 26, 2012 | 10:41 AM
Mikeh1725's Avatar
The commonrails do very well without grid heaters unlike earlier 5.9s. Sub 0s shouldn't be a problem other than a little white smoke.
Old Dec 26, 2012 | 10:45 AM
Bigg Redd's Avatar
When it gets really cold out here, I will usually plug in the block heater. It keeps the coolant temps at about 140*. Makes for real easy starts, plus I dont have to baby it until it warms up. Just get in and scoot!
Old Dec 26, 2012 | 11:02 AM
BigSilverBullet's Avatar
My truck doesn't get over 140 with my block heater. Could I have something wrong with it? Mine starts easier when plugged in but not that hot.
Old Dec 26, 2012 | 12:00 PM
Mikeh1725's Avatar
Mine would barely show on the temp gauge when plugged in (around 100 degrees)
Old Dec 26, 2012 | 04:26 PM
Bigg Redd's Avatar
Well, reading the stock analog gauge, the needle is usually on the 140* mark. Im not sure just how accurate the stock gauge is. To clarify, its give or take.....ish....right around there......approximately.....in the area of...
