Tranny on a budget what to do??
Old Dec 23, 2012 | 11:58 AM
401dodgediesel's Avatar
Default Tranny on a budget what to do??
Have an 03 Cummins and ready to upgrade tranny it's an auto and is starting to have issues not sure which way to go want to spend around 2500 don't do any serious towing just want to put a tuner to it and have some fun used rebuild a lot of reading and I'm not sure what to do any info and help is appreciated
Old Jan 4, 2013 | 04:29 PM
That<_>Guy's Avatar
Im in the same boat myself. Been doing alot of research on transmissions upgrades and for what your looking for I'd say a good triple disc TC, upgrade your valve body, and a billet input shaft just to be on the safe side. All that should still keep you in your $2,500 limit.
I'm in the process of upgrading mine but its my first transmission job so im learning as I go, but I almost got it figured out. I have the exact setup which I ordered from ATS, so after I install it I'll let you know how it holds up with my smarty.
Old Jan 4, 2013 | 06:24 PM
Demoman's Avatar
Default Transmission
Just picked up a used Dave Goerend transmission and I'm installing with rebuilt or replacement motor.Heard good things will keep you posted.
Old Jan 4, 2013 | 11:30 PM
Sebastians4x4's Avatar
Yes what would be the best bet for an upgrade on a budget? I have a 2003 5.9 2500 4x4
That seems to be having some issues.
Old Jan 5, 2013 | 12:04 AM
Demoman's Avatar
With out knowing what upgrades you have or plan to have its hard to say.Because if you upgrade torque converter without doing valve body,clutches or having shafts checked there will always be a weak area.i'll let you know how this used Goerend that was freshened with new clutches works out.Good luck
InheritedDiesel
Jun 3, 2015 09:39 PM
wilki
Feb 12, 2015 09:04 AM
Ol Goat
Jan 22, 2015 02:16 AM
B.k. Smith
10
Jan 7, 2015 02:29 PM
Ol' RED!
Dec 11, 2014 10:00 AM
