blowing white..blue smoke
Old Dec 22, 2012 | 01:50 PM
D...diesel's Avatar
Default blowing white..blue smoke
New to this forum, hope someone can help. First diesel 05' F350 6.0 Installed EGR Delete kit/injectors/oil press switch. Head gasket checked out good. Oil is leaking out the tailpipe and blowing wt/bl smoke. Any ideas?
Old Dec 23, 2012 | 09:36 AM
Mdub707's Avatar
Could be a failed turbo seal. Are you SURE it's oil, and not just wet soot? I've seen egr coolers fail and when the coolant makes it's way into the exhaust, it mixes with the soot in there and looks like oil...
Old Dec 23, 2012 | 11:37 AM
D...diesel's Avatar
Default blow white smoke
It look like soot.I drove three months with bad egr cooler.the truck blows white/blue smoke before and after delete kit
Low rpm smoke real bad and at stop lights.after I get the rpm up turbo spools up the smokes gone
Last edited by D...diesel; Dec 23, 2012 at 11:37 AM. Reason: Automerged Doublepost
Old Dec 23, 2012 | 06:33 PM
JonnyDiesel's Avatar
I wouldn't be to worried about it just keep an eye on things
Old Dec 24, 2012 | 10:49 AM
D...diesel's Avatar
So your saying let the truck blow whit smoke blue and i went through four quarts oil four days
Old Dec 24, 2012 | 10:51 AM
hey i didnt say that i said it might no be a worry i didnt see anything about goin through 4 quarts in four days thats what i ment by keeping an eye on things now somethings deff wrong
Old Dec 24, 2012 | 11:13 AM
D...diesel's Avatar
Ya deff I did watch the oil looks like getting better but not really done lot work still at same place I was think it's turbo do u know if I can fix seal on turbo or new...Thank u for the help
Old Dec 24, 2012 | 11:23 AM
It really depends on what you want to do...the seals are fixable but hows the rest of the internals of your turbo....would it just make more sense to buy a new stock turbo or upgrade it all depends on what your looking to do and what you want your bill to look like haha
Old Dec 24, 2012 | 01:36 PM
D...diesel's Avatar
I just spent $3000 on delete kit thank u for quick answers try new turbo
Old Dec 26, 2012 | 12:47 PM
c-tane's Avatar
Turbo seals aren't that hard to change out if you're handy... does take patients to get all that done.
