no turbo/boost pressure help
Old Dec 19, 2012 | 11:52 AM
rick5150's Avatar
Default no turbo/boost pressure help
nevermind problem solved
not sure how to delete this
Attached Thumbnails no turbo/boost pressure help-picture-097.jpg
Old Dec 19, 2012 | 11:53 AM
rick5150's Avatar
this is behind the front passenger side kick panel btw
Old Dec 19, 2012 | 03:00 PM
Mdub707's Avatar
What happened? Why delete it? Why not just tell us what happened and how you fixed it? Could help someone else out with a similar issue in the future...
Old Dec 19, 2012 | 03:45 PM
rick5150's Avatar
I sprayed engine cleaner/degreaser on my engine to clean it last night...i didnt get real close to anything and used the fan kind of tip..this was at a buddies i then dorve a few miles home and started trying to figure out a overhead computer problem im having with not getting power to the thing...anyways
My question is do any of these plugs in the picture mainly the 2 black ones have anything to do with the turbo at all? I had unplugged the two, checking which wires had power etc with key on and off tying to diagnose hte overhead computer issue.
I just want to make sure my problem is directly related to my powerwashing fyi i did check the 1/4" hose from my map to mainfold is still on........ at lunch in a few minutes im going to pull it off and make sure its clear and nothing blocking on the inside.
That's the original post....all I did was undo the 1/4 line from the map sensor to the manifold blow it out (it was clear to start with) then unplugged the wire clip right on the turbo looked at it seen it was dry and plugged it back in drove the truck and it was fine....
Still dealing with the overhead computer problem and its not the resistor deal I'm not getting power to the harness that it plugs into.
acj
9
Dec 26, 2015 09:54 PM
robbyS
Apr 16, 2015 02:22 PM
jhprice
Mar 29, 2015 09:36 PM
veggyoilkid
Nov 10, 2014 12:39 PM
Jeremy Babb
Chevy/GMC Duramax 01-04 LB7
13
Oct 1, 2014 06:27 AM
