R and R on the high pressure oil pump
Old Dec 18, 2012 | 09:42 AM
04 Stroke's Avatar
Default R and R on the high pressure oil pump
Hello all,
ok i have a couple questions for anyone who has replaced a high pressure oil pump. I have been working on cars since i was 15. I repair inboard ski and wakeboard boats. Is this job impossible without knowing exactly what you are doing. I have a watched a couple you tube vids and doesnt seem to bad just tedious. I would be doin it on a truck we have at work. I also have a 6.0 so i kinda want to learn so i can do it to mine if and when it happens. Any things to look out for? Any tips and tricks? let me know what you guys think
Thanks
Aaron
Old Dec 18, 2012 | 09:52 AM
Mdub707's Avatar
What year is the truck you're going to be working on? If it's an 05+, do the updated STC fitting while you're right there, and I'd highly recommend also doing the dummy plugs and stand pipes. You should have no problem doing these, not hard at all.
Old Dec 18, 2012 | 10:59 AM
04 Stroke's Avatar
Thanks for the info!! Its an 03. Ill look into the other parts if i end up doing it.
Old Dec 18, 2012 | 11:36 AM
bobfbigman's Avatar
If it's an 03 don't worry about the other parts, they are for 05 and up trucks. The first time it might take you 8 hours, the next time it might only take you 4 hours.
Old Dec 20, 2012 | 04:24 AM
dkapp0802's Avatar
if your really good you can do it without pulling the intake and egr cooler. i took all that out my first time going in there and it took a good 10 hours to get it out. and it blew man.
if you can do it without pulling the intake and egr it will only take a few hours to get to it. the only bad part about putting it back together is lining up the turbo exhaust inlet. i cracked my y pipe putting mine back in. and i have no mount bolts holding it in.
best of luck bud
Old Dec 20, 2012 | 02:55 PM
bobfbigman's Avatar
The trick to lining up the ypipe on turbo is to loosen both uppipes at the exhaust manifold, just get them loose enough to be able to manuver the ypipe into position, yes it is 4 more bolts to loosen but in the end it saves alot of time, especially if you are by youreself.
Old Dec 20, 2012 | 03:01 PM
Mdub707's Avatar
Yes, I agree. I loosen EVERYTHING I can to get that y-pipe seated properly the first shot. I loosen the up-pipes at the manifolds, the turbo mount bolts, the down pipe... literally everything.
Old Dec 21, 2012 | 08:26 AM
04 Stroke's Avatar
Wow guys thanks for all the info!! Its nice to talk to people who have actually done it! Im kinda excited to tear into it since its the first diesel i have done anything on!
Thanks again to everyone!
Old Dec 21, 2012 | 10:23 AM
Mdub707's Avatar
No problem buddy, let us know how you make out with it.
Old Dec 21, 2012 | 06:38 PM
mako mad's Avatar
04 Stroke I just had my studs done and the o rings on my dummy plugs were on their way out. 06 125000
