Fuller 5spd, backing plate, flywheel, clutch,and bell housing
Old Dec 17, 2012 | 02:31 AM
hydroshok's Avatar
Default Fuller 5spd, backing plate, flywheel, clutch,and bell housing
I spent all day trying to get this to fit in my 89. I don't know if it's a first gen thing or my 83 cab doesn't have the room. If you have a 1st gen and you are interested; I'll get measurements for you. I'm just frustrated and want to trade for an NV4500 or sell. I have everything to do the swap for the 5.9L cummins save for hydraulics, shifter, pto cover and yoke. Look at the pics and shoot me an offer. I'd like to get $1500 OBO or trade for a good working NV4500 (4wd or 2wd).
Attached Thumbnails Fuller 5spd, backing plate, flywheel, clutch,and bell housing-100_3223.jpg   Fuller 5spd, backing plate, flywheel, clutch,and bell housing-100_3224.jpg   Fuller 5spd, backing plate, flywheel, clutch,and bell housing-100_3225.jpg   Fuller 5spd, backing plate, flywheel, clutch,and bell housing-3la3j13o55e25kd5feccg1689ebf3c5471fdf.jpg   Fuller 5spd, backing plate, flywheel, clutch,and bell housing-3g43ff3j25l75e85m8ccgc879120e5e081cb0.jpg
Fuller 5spd, backing plate, flywheel, clutch,and bell housing-3g73k63lf5n15v55e5ccgccdf82168c7f176f.jpg   Fuller 5spd, backing plate, flywheel, clutch,and bell housing-3k83la3h85n25k75jaccgb5808e23e9e219e2.jpg   Fuller 5spd, backing plate, flywheel, clutch,and bell housing-3ea3gb3k15nf5g15h7ccgd1663cae07ed157e.jpg   Fuller 5spd, backing plate, flywheel, clutch,and bell housing-3g63jb3lc5ne5k15h9ccg1ed3dfc137a516ea.jpg   Fuller 5spd, backing plate, flywheel, clutch,and bell housing-3k83m83m55lb5n35f7ccgb6accc5459181b82.jpg
Old Dec 17, 2012 | 03:50 PM
plowboy1138's Avatar
U may have to do a body lift or modify the tunnel to make it fit..... I have a nv4500 but the transfer case is broke in half(driveshaft fell out goin over rail road tracks)
Old Dec 17, 2012 | 07:38 PM
hydroshok's Avatar
PM sent.
Old Dec 19, 2012 | 05:42 PM
hydroshok's Avatar
Bump...Need it gone... $1250 OBO... I know someone wants a heavy duty tranny...
Old Dec 21, 2012 | 09:19 AM
billy-bob's Avatar
pm sent
Old Dec 21, 2012 | 08:33 PM
Mark Nixon's Avatar
Is it an Overdrive or direct in 5th?
Model number?
Mark.
Old Dec 22, 2012 | 01:11 AM
hydroshok's Avatar
These are the part numbers I got from it: : 47-16-1-1, 04-7-518-16, J11A, 3931713
I'm not sure if it is direct or not. It is sitting under the truck now out of the weather. I can let you know if those part numbers don't tell you anything.
Old Dec 22, 2012 | 01:25 AM
Mark Nixon's Avatar
There should be a large tag, or plate on the transmission with a series of letters and numbers.
Something like FS160-18 or similar.
Not necessarily THOSE numbers, but a similar layout.
Mark.
Old Dec 23, 2012 | 12:47 AM
hydroshok's Avatar
It's been ground off. I can see the outline of the plate and the grind marks where it was attached.
Old Dec 29, 2012 | 12:51 AM
hydroshok's Avatar
bump...
