I made a spool aid
Old Dec 16, 2012 | 08:12 PM
luke46's Avatar
Default I made a spool aid
Been kicking the idea around for awhile. Torched a hole in my inter cooler piping below my intake welded on a 3/4" nipple at an angle toward the brake master cylinder. Took out the threaded 3/4" plug in the intake side of the head. Put another nipple in there, then ran a 3/4" braided stainless line from nipple to nipple. Seems to be a little cooler egts and slightly noticeable quicker spool up. Can't tell for sure yet but seems worth the hour or so. Could be the cold but definitely ran cooler down the highway today with a couple thousand pounds behind the truck. If anyone is interested I could post pics. I now found out pusher makes the same kit a little cleaner looking and 300 bucks compared to about 10-20 dollars max on my end. Anyone run any of these before? Line is a water heater line from Lowe's should be good for heat and water but I put a plug and cap in my truck just in case.
Old Dec 16, 2012 | 09:29 PM
H.R.D's Avatar
Old Dec 16, 2012 | 09:58 PM
luke46's Avatar
Wasn't sure if there was a interest so you will get the pics in the am. and hey we could really drink a beer I'm not even an hour from you.
Old Dec 16, 2012 | 10:30 PM
luke46's Avatar
Old Dec 16, 2012 | 10:34 PM
luke46's Avatar
I put it into the port that is about directly in line with cylinder 5 it has a hole for a half inch ratchet and I removed it via breaker bar it has 3/4" threads. There is also a port further back with a hole for a 3/8" ratchet but it has just 1/2" threads so I didn't bother with it.
Old Dec 17, 2012 | 11:33 AM
BarryB's Avatar
So basically what you are doing is "Y"ing your boost tube directly into the intake. Going to have to keep us updated how how its doing over time. I really like if it keeps the EGT's down.
Old Dec 17, 2012 | 02:26 PM
H.R.D's Avatar
Oh snap I didn't even realize. Where you at my friend? BTW the name is Jerrod, nice to meet you.
Old Dec 17, 2012 | 02:29 PM
luke46's Avatar
Ya common rail guys seem to like them but they have a bigger port to put it in. Seems maybe a fifty degree difference give or take honestly it's not much but I'll post up the true results I'm taking leave for two weeks so truck won't be moving. I've read some real good reviews on this sort of thing though.
And Jerrod this is Luke here I live over in Alamogordo.
Old Dec 17, 2012 | 02:37 PM
H.R.D's Avatar
Awesome man. I am originally from Capitan NM. So I go through Alamo often. Are you a native New Mexican? I like your spool aid by the way, would like to see it in person.
Old Dec 17, 2012 | 03:35 PM
RAW's Avatar
RAW
Interesting. Pusher makes an intake system like that as well.
Just by the title, I thought it was going to be similar to BD's Turbine Diverter Valve.
