Help truck won't rev out and want to go home for Xmas
Old Dec 15, 2012 | 05:22 PM
Turbomustang's Avatar
Default Help truck won't rev out and want to go home for Xmas
Hello I have a 98.5 with edge juice w attitude bd 100hp vp44 fass 150 I was driving down the road one day to work and it just cut out on me no power no boost could hardly hold second gear to get back home cause they truck would get hot
Well I got it home and discovered my header was cracked in half so I fixed that and swapped a t70 turbo onto it I think it's to big well I got it running and the truck is the same no power can't hold gear no boost I changed the map sensor no leaks that I can tell I need help I priced out a apps but there 700 bucks up here and I don't even know of its that is my truck over fueling and that's why it's doing this or what?
ScAnned for codes and no codes at all
Last edited by Turbomustang; Dec 15, 2012 at 05:22 PM. Reason: Automerged Doublepost
Old Dec 16, 2012 | 12:00 AM
blacksally's Avatar
if it was over fueling it should still run it would just smoke alot try taking the edge off, my truck over fuels at low boost with the injectors i havew
Old Dec 16, 2012 | 01:31 AM
Does it bog out when it over fuels?
Old Dec 16, 2012 | 01:57 AM
blacksally's Avatar
no it runs just fine blow black alot till boosted up
Old Dec 16, 2012 | 12:02 PM
Do you guys think it's the apps?
Old Dec 16, 2012 | 03:28 PM
blacksally's Avatar
i was having a problem with my truck where it was losing power then would go then lose it then go threw two codes for tps and timing for injection pump and it was as simple as the fuel filter was clogged!!! you can try and reset your apps by turn key to run unhook batterys for 30 mins turn key off hook back up then turn key on run and slowly pressing pedal to floor then slowly letting it go back up, check your filters on ur fass to
Old Dec 16, 2012 | 05:15 PM
Brand new filters possibly of a bad tank of diesel....
I unplugged my edge and drove it around finally got a p0237
Reset app no change I got that code after reset it's a new map but the way it's running I'm sure it will get dirty fast
Last edited by Turbomustang; Dec 16, 2012 at 05:15 PM. Reason: Automerged Doublepost
Old Dec 16, 2012 | 05:21 PM
RAW's Avatar
RAW
MAP shouldn't get too dirty, its filtered air acting on it.
Intercooler boost clamps, hoses, and tubes all in good shape?
Old Dec 16, 2012 | 05:30 PM
By the looks of it I can't get it to rev past 2000 rpm at a stand still
Old Dec 16, 2012 | 05:34 PM
RAW's Avatar
RAW
What kind of Edge do you have? Comp, or Juice w/attitude?
