ecm intermitantly not turning on lift pump
Old Dec 15, 2012 | 01:41 PM
427cutlass's Avatar
Default ecm intermitantly not turning on lift pump
have 01 dodge 2500 cummins.. fass 150 gph lift pump. pump wont turn on wen key cranked.. normaly runs when engine is running but itermitantly shuts off so i checked all conections etc they are all good, relay is good. im thinking ecm has internal issue. is it ok to run the fas with just ignition power instead of with ecm.. i know ecm runs it at a lower duty cycle just for cranking for some reason... just wondering if anyone has done this or ran into this, cheers
Old Dec 16, 2012 | 04:14 PM
RAW's Avatar
RAW
It will work the way you describe. Best to put a switch in though, so you can turn the pump on after the engine is started. If there is too much fuel pressure at the VP44 during cranking, it may not start.
Old Dec 16, 2012 | 05:55 PM
lauber_03's Avatar
i had the same issue, my ecm turned out to be bad but still lost power to lp after replacing ecm. i wired it through a toggle switch with inline fuse.
Old Dec 16, 2012 | 06:06 PM
RAW's Avatar
RAW
Not sure if this will help you, but here is a schematic:
Old Dec 16, 2012 | 07:23 PM
427cutlass's Avatar
Well I can't run it to a switch because I use the remote start all the time. So I wired it to ignition power, but psi is fluctuating alot! Have new filters and new fass lift pump..frustrating! And why would vp44 not fire if pump runs off acc?
landon025
Sep 8, 2015 09:21 PM
ctjkelley
Jun 3, 2015 06:01 AM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
