Gov. Springs
Old Dec 15, 2012 | 12:49 PM
24valve's Avatar
Default Gov. Springs
Yesterday I put 5k springs in my 12 valve.. I fired it up and it idles at 2600 Rpm's I took all the Shims and the smallest springs out and couldn't see anywhere that the throttle was hung up.... Any tips would be appreciated...
Old Dec 15, 2012 | 10:51 PM
captain_stabbin's Avatar
cds springs?
i believe you only do 1 or 2 clicks on them, might have to idle the truck down.
Old Dec 16, 2012 | 06:41 AM
24valve's Avatar
Which springs r u cAlling the CDs springs?
The only springs in it right now are the biggest spring and the 5k springs when I took it apart there was the big spring then the stock spring then a small spring and some shims
Old Dec 16, 2012 | 08:57 AM
turbo2332's Avatar
5k's SUCKKKKKKKKKKKKKKKKKKKKKKK!!!! to get set up for the street! best of wishes. they are very very touchy. chances are once you get the idle down the truck will die when you put it in gear or swing 500 rpms going into gear.
Old Dec 16, 2012 | 10:48 AM
angelic0-'s Avatar
Why 5k GSK ? Are you trying to spool a HX82... sure hope you have 120# Valvesprings to go with that..
Old Dec 19, 2012 | 02:01 PM
willstruck's Avatar
Can you back off any clicks? I was reading about tightening my stock springs a few clicks to raise the gov., and read that the idle will raise.
Old Dec 19, 2012 | 10:01 PM
turbo2332's Avatar
backing off a 5k??? not really they are freakin stiff, very tricky little buggers.
gunman41mag
The Sportsmen's Lounge
May 7, 2015 02:43 AM
2FordStrokers
Tire, Wheel & Suspension
Jan 5, 2015 09:23 PM
POWERSTROKEMANIAC
Dec 30, 2014 11:32 AM
jcottonoir
Nov 28, 2014 12:38 PM
Sep 29, 2014 03:00 PM
