blow by
Old Dec 15, 2012 | 08:04 AM
kylek's Avatar
Default blow by
im geting blow by out of the oil stick and filler tude not much just a lil and in geting oil in the turbo cuz its blowing in there truck has 165.000 on it runs grate i just dont like to see that smoke
Old Dec 16, 2012 | 05:25 AM
dieselman321's Avatar
Is your CDR working?
Old Dec 16, 2012 | 06:10 PM
detroitdiesel idi's Avatar
Bad cdr valve is most likely reason for oil in turbo ..small amount of oil in turbo wouldnt hurt but id change cdr valve anyway...theyre recomended as part of a tuneup ..as for blowby i wouldnt worry unless its a lot of smoke puffin out ...most likely has slightly worn piston rings or cylinder ...but id change the cdr n call it a day...its on passenger side valve cover it says notice this end up on it ..they usually go for 59.99 careful getting them at a local auto parts store as they usually call them a egr valve.
Old Dec 18, 2012 | 08:46 PM
kylek's Avatar
i got a new cdr and it never stoped the blowby cud it be the k&n oil filter
Old Dec 21, 2012 | 09:59 AM
JorgeNY's Avatar
where did you get the cdr and what brand? I replaced my cdr with an ac delco unit and it did nothing to stop the oil but i have a 1/4 million miles and im sure there is blow by. Im looking to get a Mann provent, it goes in line between cdr and turbo, the oil goes through a filter and collects in the bottom preventing oil from going through the intake. But they cost $150
Ditch the K&N filter, they sacrifice filtration for flow and people often make the mistake of over oiling, not to mention a pain in the *** when it comes time to clean it.
Old Dec 24, 2012 | 09:49 AM
Ok lets try this again....nothing will fix your blowby except a bore and a new piston rings job! thts what blow by is compressed air escaping past worn rings or cylinder wall.. No changing the oil filter wont help nor would the cdr help.the cdr will only hepl to keep oil outta the turbo if u replaced tht n still have oil goin into the turbo its probally a seal inside the turbine housing.
Old Dec 29, 2012 | 03:01 AM
kylek's Avatar
it was the k&n oil filter just like i thought
Old Jan 1, 2013 | 07:16 PM
acesneights1's Avatar
How can an oil filter cause blowby ?
What you are describing is pretty normal for a 6.5 with that kind of mileage. Unless it's blowing smoke out the breather I would not worry about it.
If it looks like this...you got problems...
rollover
May 5, 2015 07:33 PM
EasTxOilfields
18
Apr 2, 2015 01:51 PM
jedder21
Mar 7, 2015 09:47 PM
Nov 10, 2014 08:10 AM
CumminsCrazed
Price Quote - Request A Price
Oct 13, 2014 02:35 PM
