headlights problem
Old Dec 14, 2012 | 08:31 PM
mule97's Avatar
Default headlights problem
On my 03 ram my headlights flicker on and off like there is a short don't see any wires that are bad HELP
Old Dec 15, 2012 | 07:38 PM
minncountryboy's Avatar
Check the relay? Fuses?? You don't have h.I.d.s. do you?
Old Dec 17, 2012 | 04:00 PM
mule97's Avatar
no i don't still stock
Old Dec 17, 2012 | 04:11 PM
Have you checked your grounds? I'll have to look at the wiring diagram when I get home for ya
Old Dec 17, 2012 | 07:32 PM
mule97's Avatar
thanks that will b great
Old Dec 17, 2012 | 09:27 PM
Well mule.. I looked at the wiring diagram in the ole chilton book and from what I can see is it could be a couple of different senerios.. cause it appears your headlights take the same route as my cargo lights do on my 06 and they dont work at the moment cause the stealership said they need to hook up the computer to it to see what's wrong with it... But anyhow.. your headlights switch, and multifunction switch both go through the instrument cluster. then go to your fcm/tipm (front control module/ total integrated power module) then to your headlights... And if all your wiring/ connectors are all good snug and not burned or loose, and the bulbs, relays, fuses are good.. If it was me I would go to the dealer so they can hook up the computer trace the shorting issue and you can fix the right part... But i would also check your batts, and connections, and probably the alt. cause my 06 was throwing wired Ecm codes and what not and I cleaned my posts and and it all went away.. just some ideas for ya.. if im wrong I hope someone else chimes in on this thread also so we both can learn haha.. man.. that's the only sucky deal with all the fancy electrical crap under our hoods..
If this don't help my apologies.. I don't want you just throw parts at it and costing you more money man
Last edited by minncountryboy; Dec 17, 2012 at 09:27 PM. Reason: Automerged Doublepost
Old Dec 18, 2012 | 12:36 AM
CHEMMINS's Avatar
Is it just headlights flickering or do dash and dome do it as well? What about fogs?
Old Dec 18, 2012 | 03:44 PM
mule97's Avatar
no just head everything else is ok it dont do it all the time. i have after market fogs wired to a switch by there self.
burndiesel
10
Feb 7, 2023 01:15 AM
jeremy01995
Sep 14, 2015 06:34 PM
Rabbitjbu
Jul 28, 2015 06:03 PM
swartile
May 8, 2015 01:03 PM
carid
Diesel Bombers Sponsors
Apr 7, 2015 07:30 AM
