losing it prime
Old Dec 14, 2012 | 01:53 AM
hulse09's Avatar
Default losing it prime
lately my truck has been losing it prime after only sitting for like 1/2 hr. cant seem to find where its coming from. anyone know where i should start or hear of anyone having probablems. say it will crank and crank but wont start. but if i bump the starter and let my raptor 150 run say i do that 2 or 3 times and it fires right up and runs fine.
Old Dec 14, 2012 | 06:36 AM
RAW's Avatar
RAW
Changing the overflow valve wouldn't hurt. They aren't very expensive, and can cause a lot of issues.
The return line banjo bolt on the back of the head is another common spot. Fuel won't leak out, but it will let air back in if it is loose.
Old Dec 14, 2012 | 06:54 AM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
i have used shop air in the tank to find leaks. be careful and not get too much.
Old Dec 14, 2012 | 08:36 AM
blacksally's Avatar
are the injectors kindal ike ford ones were they can leak down????
Old Dec 14, 2012 | 08:39 AM
diesel pap's Avatar
cummins is fuel pressure only
Old Dec 18, 2012 | 10:57 PM
hulse09's Avatar
i still can find the probablem i still hv to cycle the lift pump even after sitting for an 1hr it will lose its prime. more input please
Old Dec 19, 2012 | 06:42 AM
diesel pap's Avatar
did you pressure the tank up a little.
Old Dec 19, 2012 | 07:01 AM
RAW's Avatar
RAW
What have you done so far so we don't repeat something?
Old Dec 19, 2012 | 10:52 AM
tiremann9669's Avatar
Are you running the stock sending unit ? Rust was a problem with mine
Old Dec 20, 2012 | 10:39 PM
hulse09's Avatar
checked the overflow valve put a wrench on my fittings all seem tight. changes fuel filter with ne o-ring. have not put and pressure to it yet. and im sure its still the stock sending unit. all i did was put a raptor 150 on it. i notice soon as u turn the truck off the fuel press drops right off but shouldnt it have some even with the lift pump not running? if i cant find anything could i just run my raptor 150 hot all the time not one when u go to start the truck.
