truck shakes when ideling
Old Dec 12, 2012 | 09:08 PM
89&92cummins's Avatar
Smile truck shakes when ideling
im new to this forum and I just got my truck, its a 1992 3/4 ton 4 wheel drive 5 speed. when its ideling or when you let out of the throttle the whole cab shakes, I don't know if there is a motor mount broke or trans mount, but as soon as you give it throttle it leaves. any info will help. thanks
Old Dec 12, 2012 | 11:45 PM
turbo2332's Avatar
check all your mounts, thats where my money is.
Old Dec 13, 2012 | 10:09 AM
tampabaybill's Avatar
You might also want to chech your idle rpm. If its set to low your truck will shake pretty bad, shudder and almost stall when you take off.
Old Dec 16, 2012 | 02:36 PM
peterbuilt1024's Avatar
Motor and tranny mounts is a first thought also could be fuel filter primary and or secondary. Keep us updated.
Old Dec 16, 2012 | 08:25 PM
thanks for all the replies, I haven't had time to check on it but i will soon. also the steering is VERY loose and I have tracked it to the bottom of the steering shaft that connects to the gear box. it is warn out on the inside, I don't know if I should find a shaft in a scrap yard, or buy a borgeson, or there is a rebuild kit on rock auto, im 16 and on a limited budget so any info will help on this subject also.
Old Dec 16, 2012 | 08:32 PM
92betsy's Avatar
Hell I'm 29 and on a limited budget, or else my steering would be better. I noticed I swerve a little in the wifes car since I'm used to the trucks sloppy steering.
Old Dec 16, 2012 | 08:41 PM
turbo2332's Avatar
hahahahahahaha save up and buy a new one boy. i think most of us are on a limited budget, we just spend the budget we have on our grease smashers.
Old Dec 16, 2012 | 09:12 PM
geddy's uncle's Avatar
The typical old Dodge pickup is not steered. It is guided. Get a Borgeson and start steering.
doublehbar
13
Aug 9, 2015 12:35 AM
clarthom
8
Mar 5, 2015 07:27 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
Dec 3, 2014 09:40 AM
Oct 14, 2014 08:40 AM
