Starting issue
Old Dec 12, 2012 | 04:58 PM
cummincider's Avatar
Default Starting issue
I just bought a new battery and had 4 k gsk put in truck was running great quick start everything great it sat for 6 days cause I had to work and tried starting it grid heater warmed up fine then I try to turn over I just get one solid click then nothing any help would be great thanks
Old Dec 12, 2012 | 05:22 PM
H.R.D's Avatar
Batteries still charged? Try jumping it or putting a charger on them?
Old Dec 12, 2012 | 05:50 PM
Yep there juicy first thing I tried possible it's grounded some were or that my starter just said few outta no were
I just double checked the batteries and there full charged
Think it's just time for a new starter any way to check thanks
Last edited by cummincider; Dec 12, 2012 at 05:50 PM. Reason: Automerged Doublepost
Old Dec 12, 2012 | 09:07 PM
daveO's Avatar
Try giving the starter a couple taps with a hammer.
Old Dec 13, 2012 | 04:13 PM
I beat the hell outta it just that one click then nothing I was told to check tot see if I got power going to it would I just take a volt meter and put one on the positive wire under the starter and ground the other to the block again all replays appreciated
Old Dec 13, 2012 | 06:51 PM
geddy's uncle's Avatar
Might just be the starter solenoid contacts all burned up. The starters themselves are pretty beefy, but, the OEM solenoid contacts are kind of smallish for carrying the sudden burst of current needed for kicking the Killer B into life. google up "Larry B's starter contacts". I've had a set in for probably 8 years, before the starter itself suffered a broken mount and had to be replaced. I installed new contacts on that one before the install, and have had no problems.
Old Dec 14, 2012 | 04:11 PM
Yea I had seen that on another post does anyone have the fuse box diagram mines Mia and idk what fuse is the starters
Old Dec 16, 2012 | 06:02 PM
gyayo2012's Avatar
try your batery cables mine seem to do that everyonce in a while they get loose.. try cleaning them and tightening them again... mostly happens to my ground on driver side..
dskewes14
Sep 14, 2015 09:19 AM
06kyleP
Jul 19, 2015 06:10 AM
Squirt
Jun 19, 2015 12:40 PM
custom7.3
Nov 24, 2014 05:16 PM
7.3stroke
Oct 27, 2014 06:25 PM
