blue and white smoke on cold start
Old Dec 12, 2012 | 03:31 PM
jdbigblue12v's Avatar
Default blue and white smoke on cold start
i live in new york and its been getting pretty cold at night and i park the truck fpr about 9-11 hours a night before driving again. when i cold start it with the grids on it starts up in a half click, but rough idle and lots of blue/white smoke. this only started happening since it got cold and i have a feeling bad lift pump may be causing this too. brand new fuel filter last week and when doing a w.o.t pull on the highway (with h1c rightnow) it hits 20-psi for about 5 seconds and then falls off to about 10 engine bogs and sputters. what the hell is going on??
Old Dec 12, 2012 | 04:35 PM
VTstrokin's Avatar
Drop off in boost and the engine "bogging down" at highway speeds is a hint that the lift pump is going.
Old Dec 13, 2012 | 02:14 AM
Would lift pump to cause back fire and blue smoke when i floor it? Thats what happens when i said it bogs down an boost falls off
Old Dec 13, 2012 | 11:13 AM
VTstrokin's Avatar
Lose power..backfire..blue and black smoke will come from the exhaust - JustAnswer
I found this online, try the link above. I know it's showing a newer Cummins engine, but its worth a shot. Hope it helps!
Old Dec 13, 2012 | 04:42 PM
Well i gradually rev-ed the truck up to 2200rpm and it blows alot of white smoke and sputters an back fires. Please tell me this is a. Sign of a bad lift pump and not a gauged cam like i have been readig
Old Dec 13, 2012 | 06:51 PM
VTstrokin's Avatar
Wish I could man, I just don't know enough about it to be able to tell you, but maybe someone else will chime in and help you out a bit more.
Old Dec 13, 2012 | 07:42 PM
cumminskid92's Avatar
run a temporary fuel psi gauge into the cab and see what the fuel pressure is at WOT
My truck was doing the same thing so I replaced my lift pump but it didn't fix the problem. I dropped my tank and found that the screen on my pickup tube had collapsed and sucked into the line thus reducing flow. Just something to check before you but a lift pump
Last edited by cumminskid92; Dec 13, 2012 at 07:42 PM. Reason: Automerged Doublepost
Old Dec 13, 2012 | 07:57 PM
Ill check that tonight
Old Dec 13, 2012 | 08:23 PM
plowboy1138's Avatar
It's normal for one of these old trucks it should clear up and smooth out once it gets the cylinder temp up
On the high way it sounds like ur lift pump goin or slipped timing
Last edited by plowboy1138; Dec 13, 2012 at 08:23 PM. Reason: Automerged Doublepost
Old Dec 14, 2012 | 01:59 AM
How would the timing slip? Never had the case open and runs mint until higher rpms and when boost comes up demanding more fuel i feel like it is because of fuel pressure droppin to low
bump please help!!
the same problem i have!!
Last edited by jdbigblue12v; Dec 14, 2012 at 01:59 AM. Reason: Automerged Doublepost
