injectors and turbo
Old Dec 11, 2012 | 11:38 PM
hulse09's Avatar
Default injectors and turbo
i have a 2000 cummins 5spd SB clutch, edge comp drag, smarty, raptor 150, cold air, pusher intake, stock turbo and injectors. edge CS for gauges. i was wondering what a good turbo to run is and injectors. would like to make 450hp and not have crazy egt.
Old Dec 11, 2012 | 11:40 PM
H.R.D's Avatar
100 hp sticks and an S300 series turbo would be a good combo.
Old Dec 12, 2012 | 03:14 PM
lobsterman04's Avatar
x2 on the s300 (62-64mm). 62 with 100 sticks and 64 with 150's.
Old Dec 14, 2012 | 01:56 AM
hulse09's Avatar
what should i do first?? say i cant drop 1500 in a turbo but i can spend 500-600 on injectors. say what are a good set of 150.
Old Dec 14, 2012 | 08:06 AM
chuffysplace's Avatar
Would you consider compounds? I dont know if it's possible to re-use the existing turbo too. Maybe someone will chime in with info on that. Perhaps a kit exists, so we don't have to do custom fabrication. I'm looking for that info as well. If I can get more info, I'll let you know. Some guys are running compounds and I've read real good things about them.
Old Dec 17, 2012 | 08:42 PM
hulse09's Avatar
im thinking injectors first. a set of 150hp should do for now just gotta keep an eye on my EGT
Old Dec 18, 2012 | 04:16 PM
I did 150's with a boost fooler and the truck did great until I added the quadzilla...Just watch your parameters (EGT, trans temp, boost) and you should be ok.
Old Dec 18, 2012 | 04:36 PM
Farmboy 2.0's Avatar
If you only want 450 id look into 85-120 hp injectors. And then go with a 62mm turbo like a killer b from bd diesel, phatshaft from IIS, or Silver and Super phat shaft 62 turbos. I had a set up very similar to yours a number of years ago. With 100's, Edge Juice, Air Dog, and a Super Phat Shaft 62 did right about 450-460 with controlable egts
Renteria1217
19
Oct 13, 2015 01:36 AM
Whitereaper12v
13
Jan 25, 2015 07:05 PM
tumble72
8
Nov 27, 2014 10:31 PM
strokin97
Sep 30, 2014 11:59 PM
