Where do you get Performance parts
Old Dec 11, 2012 | 04:49 PM
michael.shafto's Avatar
Default Where do you get Performance parts
Hello!
Now that I am on the road to solving my cylinder head issue (head was bad, block ok!), where do you go to find performance parts. Everyone seems to carry for the Duramax, but not so much for the ole 6.5L I am looking for tractor stacks, performance heads, new turbo, and a lift kit. Nothing too crazy, just want to get some 265/75R/16s underneath her. will they be compatible witht he stock rims? any help will be greatly appreciated!
Mike
Old Dec 11, 2012 | 10:05 PM
Turbine Doc's Avatar
265/75/16 was stock tire that came on mine no lift required, looks like yours in avatar is a dually 3500 2x4 or 4x4 ??? up date your signature. Auto or manual trans, as a 96 you are OBD-II so will need a reflashed PCM vs chip, h/o marine injectors, ATT turbo look at my signature is about as far as you can go with bolt on. That will get you to about 250rwhp up from 185hp at flywheel from factory with auto trans maybe a little more with manual since auto eats up about 40-60 hp faster you go.
Before adding for power and bigger tires you need to look a $$ spent for longevity & basic maint 1st, then go for some power mods, also you being a dually probably you have 4:10s not good for speed/economy may need to go to a 3:73 ratio for good blend of power/economy.
Need to know where you are-and goal for what the build up is for to offer best advise.
Heath Diesel good place to start for most stuff you seek. Not many folks support 6.5s Diesel does nothing but 6.2/6.5 also owns operates the worlds fastest 6.5 record set @ Bonneville 158 mph going for more hopefully on next years "salt".
Old Dec 20, 2012 | 06:15 PM
racer55's Avatar
Kennedy Diesel offers 6.5 support as well.
Some other aftermarket vendors are Leroy Diesel.
Alligator Performance for exhaust.
DSG from Canada also has some 6.5 offerings.
Old Dec 20, 2012 | 06:40 PM
kyled's Avatar
Good to hear your solving your problem little by little. I like finding stuff on craigslist. I know it sounds sketchy, but I have had great success. I saved money and met some really cool people who like working on their trucks.
Old Dec 21, 2012 | 09:35 AM
JorgeNY's Avatar
Performance heads might be had from pennisulardiesel.com
Stack kits are easy to get, most are universal but cost big bucks.
A good turbo upgrade for example would be a holset hx series turbo with at least a 14cm2 turbine housing.
with all that said, a tuned ecm would also be a nice upgrade and will bring out the full potential of the turbo.
As for lift kits, they can be had from almost any off road internet site.
Romines44
Apr 26, 2015 09:56 PM
Adam Sanders
LB7 Performance
Jan 21, 2015 06:57 AM
Nov 3, 2014 01:40 PM
Sculpturesylvan
Oct 18, 2014 10:40 PM
Sculpturesylvan
Oct 18, 2014 10:19 PM
