lift pump taking 35 seconds to prime HELP
Old Dec 10, 2012 | 09:16 PM
bob65's Avatar
Default lift pump taking 35 seconds to prime HELP
just replaced my lift pump in my 03 dodge 5.9 cummins, this has been upgraded to a 05 in tank lift pump, but it takes 35 - 45 seconds to prime, is there a relief valve or check valve on the injection pump that i need to check and if so where is it located
Old Dec 10, 2012 | 10:43 PM
Diesel Addict101's Avatar
Was it professionally done or by a normal person? Im not an expert on this but I'm sure theres a bleeding procedure for any fueling replacements. Not exactly sure what the procedure is but my guess is you have air in your lines could just correct itself but I'll let someone else chime in on this one.
Old Dec 11, 2012 | 08:19 PM
bob65's Avatar
did it myself, i'm a heavy equipment operator and do a lot of the mechanicing myself, and on the bigger diesel engines there is a check valve or relief valve but i'm having trouble with this 5.9
Old Dec 12, 2012 | 07:37 PM
South Texas Goat's Avatar
My 3rd pump to replace, never had that issue, maybe you got a bad pump. Pop the hose lose at the filter check flow there, pressure to if you can. I only 1 time had to cycle the key to get fuel thru the filter, started right up.
Old Dec 13, 2012 | 06:43 PM
ecjammer's Avatar
I gotta agree with South Texas Goat. Could be a bad or weak pump. I would also chech the voltage to your pump to make sure that it is correct. Did you replace your filter? Also check all lines to ensure that they are tight with no air leaks or crimps.
Old Dec 14, 2012 | 06:32 AM
steved's Avatar
Instead of pulling the line, loosen the filter housing...see how much fuel gets pumped out.
Its 500ml/15 seconds (or something like that) is what they expect flow rate to be?
There is no relief valve, they are self bleeding system.
twinturbo12v
5.9L CR Performance
Nov 26, 2015 02:06 AM
landon025
Sep 8, 2015 09:21 PM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
