D350 advice
Old Dec 10, 2012 | 07:52 PM
logan lacey's Avatar
Default D350 advice
hey i got 1993 D350 and was wandering what else is a fast cheap way to give her more juice already messed with the fuel pin. It is completely stock. any advice?
Old Dec 10, 2012 | 09:32 PM
92betsy's Avatar
Gauges 1st, then look for more power. Welcome to the 1st gen club. Plus what trans do you have. A auto won't handle much in stock form.
Old Dec 11, 2012 | 10:12 AM
tampabaybill's Avatar
As said gauges, egt, boost,fuel pressure then go to work on the IP full fuel screw,smoke screw etc. When you do that you will need more air so time for BHAF, 4 in.exhaust and 14 or 16 cm turbine housing and 60mm compressor upgrade or a different turbo. Then its time for a TransGo TFOD kit and a good torque convertor and then upgrade injectors. As you can see its a slippery slope and once started seldom ends, but its a fun trip...........Bill
Old Dec 11, 2012 | 11:14 AM
1993firstgennewbie's Avatar
you can get alot of power out of these pumps but if you dont get gauges alot of things can go wrong. You could melt your pistons, your 2 thousand dollar motor could run away and live off its own oil until it turns into shrapnel. Dont be a cheap bastard get some gauges and then have some fun
Last edited by 1993firstgennewbie; Dec 11, 2012 at 11:14 AM. Reason: Automerged Doublepost
Old Dec 13, 2012 | 05:38 PM
Ya wouldnt want a run away on my hands. what gauges do i need? soon hope to get a new tranny. it has a 4 speed auto. Thank you guys so much
Old Dec 14, 2012 | 12:11 AM
92betsy's Avatar
EGT gauge, boost, fuel psi, and trans temp won't hurt either.
brianj2077
Aug 4, 2015 09:06 PM
Spaky6.0mudder
Aug 3, 2015 08:54 PM
twm011
Feb 24, 2015 09:11 AM
jrsavoie
Feb 6, 2015 09:44 PM
Nov 3, 2014 08:10 AM
