egr delete
Old Dec 10, 2012 | 07:49 PM
deiselfuelonly02's Avatar
Default egr delete
Which is better, egr delete or the bulletproof cooler?
Old Dec 10, 2012 | 07:59 PM
Karls03's Avatar
Given that I picked up throttle response with an EGR delete, I think that was the better option.
Old Dec 10, 2012 | 08:07 PM
Curry's Avatar
Delete it and forget about it.
Old Dec 11, 2012 | 12:36 PM
bkmac's Avatar
That is the same thing the service manager at my Ford dealership said!
Old Dec 11, 2012 | 12:50 PM
Mdub707's Avatar
Both are far superior to stock. Obviously with it deleted you've got NOTHING to worry about, but the bulletproof unit is really nice if you live in a state where they do visual inspections (you're in TX, so I doubt it...).
The oil cooler is the one you want to keep an eye on...
Old Dec 12, 2012 | 07:54 AM
HeavyAssault's Avatar
Truck heavy state like TX if it's emissions checked the tech may know what to look for. A "sneaky" pipe would work wonders for the visual. It doesn't help the EGR cooler issue for a long term solution.
Given it is Texas I think the attitude would be delete that POS EGR system and be happy.
Old Dec 12, 2012 | 07:58 AM
dkapp0802's Avatar
i welded mine shut. so if i go to sell it to a dealer or whatever it looks like its there but really its been deleted
i noticed more throttle awsell i agree with curry delete that sum *****
Old Dec 12, 2012 | 12:30 PM
Mdub707's Avatar
Same here. Biggest improvement that Karl and I both noticed is that when you pull into your driveway or somewhere after a long drive, and are waiting for EGT's to come down under 400*, it peels temps off way faster. I used to wait a while for it to drop now it seems to come down real quick.
Old Dec 12, 2012 | 02:57 PM
Karls03's Avatar
Agreed, if it is leaking coolant, replace it, delete it, but don't cap/weld it. While the cap/weld will reap the other benefits, that leak is still there, ticking away.
Yes, my EGTs do fall off quicker, MUCH quicker when I am on the loud pedal.
Old Dec 12, 2012 | 05:09 PM
Mdub707's Avatar
From what I understand, if the ends are welded, and the cooler does fail, it just fills up with coolant and that's it... nothing else happens. It's not a large volume in there so you only lose a tiny amount of coolant. Myself, I'm too OCD for that, and it would bother me knowing it might be in there...
