s.o. or h.o. vp44 on h.o. truck?
Old Dec 10, 2012 | 07:16 PM
smedley's Avatar
Default s.o. or h.o. vp44 on h.o. truck?
is there any gain in running a s.o. pump over the h.o.? i am reading mixed reviews and was wondering because i am going to be replacing my vp44.
am i going to see a gain with the s.o. pump? my truck has airdog 150,s&b cold air, edge comp, exhaust
Old Dec 10, 2012 | 08:47 PM
RAW's Avatar
RAW
SO can properly fuel larger injectors properly. SO is good up to 300HP, HO up to 200HP Max. Best bang for the buck is an SO pump.
Old Dec 11, 2012 | 01:03 AM
Ramitt's Avatar
If you have a s.o truck you have to run a s.o if you had a h.o truck you can run either. S.o is good for more hp. H.0 can only support up to like 500hp where the s.o is good for 700hp.
Old Dec 11, 2012 | 05:05 AM
Only problem is if you order a SO pump most places will not accept a HO Core.
Luke
Old Dec 11, 2012 | 05:48 AM
smedley's Avatar
Not sure what pump my truck has. I have tried to look it up but cant find anything on it.
Old Dec 11, 2012 | 04:36 PM
CumminsCrazed's Avatar
p pump.......
Old Dec 11, 2012 | 05:20 PM
RAW's Avatar
RAW
p pump.......
Give 'er, money bags.....
Farmboy 2.0's Avatar
What is your end goal for the truck?
Old Dec 11, 2012 | 05:50 PM
shellinger's Avatar
whats the difference between the pumps? why would s.o. pump be able to push more hp than h.o. pump?
Old Dec 11, 2012 | 05:55 PM
Standard output has larger plungers in it i guess.
