lift pump
Old Dec 10, 2012 | 04:33 PM
94yotter's Avatar
Default lift pump
i have a 2001 24 valve is the factory lift pump in the tank or on the frame rail behind the fuel filter because it looks like there was one next to the fuel filter.
Old Dec 10, 2012 | 04:35 PM
RAW's Avatar
RAW
If it is factory, it will be in the tank, or mounted to the block behind the fuel filter.
To find out, turn the key on and bump the starter. Jump out and listen for the hum of the fuel pump.
Old Dec 10, 2012 | 04:42 PM
94yotter's Avatar
ok i also cant get the truck running i think its the lift pump, what kind of fuel pressure should i see if the lift pump is running with the truck off, or does the truck have to be running.
Old Dec 10, 2012 | 05:30 PM
Bryce's Avatar
When you bump the starter pump should run for 25 sec. If pressure is below 10psi replace the fuel filter and try again. Stock pumps will put out max of 12psi but are not good enough to keep psi up at wot. If psi is below 10 at wot its time for a new lift pump or filter. Have you bled the injectors?
Old Dec 10, 2012 | 05:53 PM
chadcycle 2500's Avatar
It should build pressure even with the truck off bump the starter like they said,maybe loosen the line at the back of filer see if it squirts out. Get a gauge it is wery helpful to keep an eye on this
Old Dec 11, 2012 | 12:14 PM
94yotter's Avatar
yes i bled the injector and it ran for like 20 seconds but it wouldnt idle i had to stay on the throttle.
Old Dec 11, 2012 | 12:36 PM
With out seeing it it's tough, I;d put a gauge on first thing,see what it does in this 25 second "run",check fuelfilter itself,check the input voltage to liftpump again durring the "run"to make sure it is staying powered up,yes this is a bit to do but you will know what you have going on here,could be something elsebut ...
Old Dec 12, 2012 | 05:12 PM
94yotter's Avatar
ill get a gauge on it tomorrow, what kind of input voltage should i see at the lift pump just 12 volts.
Old Dec 12, 2012 | 05:49 PM
RAW's Avatar
RAW
Yep, 12 volts. Check the ground circuit as well!
Old Dec 12, 2012 | 06:38 PM
94yotter's Avatar
is there any kits forsale that come with all the hardware and the gauge for fuel pressure at a reasonable price
