uh oh...head gasket time
Old Dec 9, 2012 | 10:39 PM
CumminsCrazed's Avatar
Default uh oh...head gasket time
well guys as the title says, its time for me to get a head gasket.
truck started leaking oil from the front of the head about a week ago. not leaking horribly bad, but once the engine warms up and oil thins out itll leak probably about a 4x6 postcard size spot within about 5 mins of turning the truck off.
Anyway, ive been told the best route to go would be to replace with an OEM Cummins head gasket and obviously head studs.
Im also considering possibly o ringing the head gasket, but i have no clue what that entales, how to go about it, or if any shops around here will do it. So im asking you guys, educate me on o ringing a head/head gasket. Also, curious on what range of money id be looking at to replace head gasket as well as o ring the head/head gasket. Can be what you shop owners would charge, or what you guys have paid as a customer. Just needing to get some numbers in my head.
Let me know guys!
Thanks!
Old Dec 9, 2012 | 10:52 PM
It could be the front cover leaking.
Luke
Old Dec 9, 2012 | 11:01 PM
no, its definitly coming from the front left corner of the head.....entine front edge of head is wet...
Old Dec 10, 2012 | 07:50 AM
RAW's Avatar
RAW
O-ringing is cutting a groove into your head to place a solid piece of wire in. This wire clamp down harder on the fire ring of the stock head gasket. You will need someone to cut the groves for you, and I would get them to install the wire as well. There is a specific thickness of wire, along with a specific depth and width of grove to cut. One that it done, it is business as normal replacing the head gasket.
Old Dec 10, 2012 | 09:21 PM
ok, well i talked to a guy today that said he would do o ringed head gasket with arp studs and a port/polish job for around 1500ish
Old Dec 10, 2012 | 09:25 PM
RAW's Avatar
RAW
Is that with labor and everything? Drive in, $1500, drive out?
Old Dec 10, 2012 | 09:40 PM
yup, he quoted labor parts etc
obviously thats just an estimate as he hasnt seen the truck yet, so it could be more, i wouldnt be suprised if it maybe was,
POWERSTROKEMANIAC
Dec 21, 2014 09:59 AM
Diesel Addict
Price Quote - Request A Price
Dec 10, 2014 06:52 PM
turbodiesel123
6.2L & 6.5L Performance
Nov 28, 2014 08:36 PM
HE22871
Nov 26, 2014 03:15 PM
1994cummims
9
Oct 15, 2014 11:37 AM
