94 cummins only starts when fuel filters full
Old Dec 9, 2012 | 08:48 PM
jonesy9310's Avatar
Default 94 cummins only starts when fuel filters full
the only time i can get my truck started is when i put diesel in the fuel filter then it runs for about 30 seconds and dies anyone know what the problem is?
Old Dec 9, 2012 | 11:03 PM
tiremann9669's Avatar
Bad fuel line filter needs to be full all he time
Old Dec 9, 2012 | 11:16 PM
jonesy9310's Avatar
So you dont think thered a leak in the line and not the lift pump?
Old Dec 9, 2012 | 11:59 PM
cumminss_bmxer's Avatar
the feed line coming from the tank unit is notorious for rotting out and leaking air. look at the lines coming from the tank and ill guarantee its rotted out. save yourself the future headache and put in a sump. i did a sump and all new 3/8'' lines to the lp and havent had a single problem since.
Old Dec 10, 2012 | 09:13 PM
jonesy9310's Avatar
can someone tell me how much fuel line i need to replace from the tank to the lift pump and what size
got the truck running but if i press on the pedal and let off real fast it dies is it something to do with the injection pump being turned up?
Last edited by jonesy9310; Dec 10, 2012 at 09:13 PM. Reason: Automerged Doublepost
Old Dec 10, 2012 | 09:23 PM
The fact that you're getting air in the system points to a line and they're 3/8, could possibly be the sending unit also so like said above might need a sump or a draw straw.
Old Dec 10, 2012 | 09:50 PM
jonesy9310's Avatar
Thanks got it runnning i guess my fuel gauge is off i haf air in the lines from running out of fuel. But now when i hit the gas real fast and let off it dies idk if its from the injection pump being turned up or what
Old Dec 13, 2012 | 06:39 PM
geddy's uncle's Avatar
Just need to bring your idle up by a couple hundred rpm. Got nothing to do with turn-upped-ness. Just needs to be sped up a little. Mine did that 2-3 times over the course of the last 15 years.
Old Dec 19, 2012 | 02:05 PM
willstruck's Avatar
Not sure about a 94, but on my 97 there is a prefilter before the heater that gets overlooked. Mine was so gummed up that fuel was forcing itself around the screen... Probably never cleaned in the 330,000 miles before I discovered it...
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
Collin Dow
Feb 21, 2015 08:18 PM
moneypitk5
Feb 12, 2015 11:01 AM
