more boost?
Old Dec 9, 2012 | 05:32 PM
codyawise's Avatar
Default more boost?
My truck is all stock except for exhaust bigger air box and intake horn. Truck has no problem hitting 26 psi but it will not go over 26. Is it just cuz I dont have a programmer or what's goin on?
Old Dec 9, 2012 | 06:22 PM
blacksally's Avatar
you need extra fuel and air to get more boost if you put injectors in or a programmer etc
Old Dec 9, 2012 | 06:47 PM
codyawise's Avatar
So it is only cuz my trucks pretty much stock?
Old Dec 9, 2012 | 07:54 PM
blacksally's Avatar
thats good boost 26psi i only make 35psi i need a bigger more fuel flow so im gettin a fass system
Old Dec 9, 2012 | 08:14 PM
shellinger's Avatar
the highest my truck has ever hit is 42 psi with all the mods in my signature. would def. recommend getting a nice aftermarket lift pump like a fass or air dog or dragon fire before getting a programmer. try and get one that comes with the upgraded larger diameter fuel line to feed the vp44. then get a programmer. that way you wont starve your vp44 of fuel causing it to eventually fail.
Old Dec 9, 2012 | 08:16 PM
chadcycle 2500's Avatar
Thats what they do stock
Old Dec 9, 2012 | 08:52 PM
RAW's Avatar
RAW
Auto or Manual transmission? If manual, you can pinch off the wastegate hose. Auto's are trickier to deal with. A J-Hook will work on the Auto trans turbos to gain more boost.
You could also put a boost elbow in if it's a manual.
Old Dec 10, 2012 | 03:42 PM
codyawise's Avatar
Alrighty thanks guys and yea its an auto
Old Dec 10, 2012 | 04:32 PM
RAW's Avatar
RAW
It's a little more involved to block that wastegate off, as it is a steel tube compared to a hose. When I plugged mine, I pulled the tube off and threaded a machine screw into the tube inlet with red loc-tite on it. After that set up, I ground the head off with the bench grinder. Reinstalled everything, and went from 26PSI to 34PSI.
Old Dec 10, 2012 | 06:54 PM
Ramitt's Avatar
For you hy 35 guys you can upgrade to a hx35( What manuals use) You will gain a little bit more pep but with stock injectors and past 35lb's of boost your not gaining anything. I wouldnt take it past 40lb's anyway unless you want a new turbo
