Injectors
Old Dec 9, 2012 | 10:00 AM
bigred91's Avatar
Default Injectors
Alright so when I'm driving down the road sometimes at about half throttle something is going on in the motor and it makes the truck bounce but once I give it more gas or lay off it stops. I'm pretty sure I need injectors. It has 143xxx miles on it and I have an extended warranty from ford until 144000. Do y'all think that injectors would be covered by the warranty? Cause I know that this is usually when injectors will start needing to be replaced anyways
Old Dec 9, 2012 | 03:49 PM
Mdub707's Avatar
There is no set time as to when an injector will "need replacing" I know guys with 2x the miles of you on original injectors. I also know people that didn't make it to 1/2 the miles you're at and needed some too.
What oil are you using and what oil filter are you using?
Try a couple of bottles of rev-x before you spend the money on injectors.
In my experience with warrantying sticky injectors, Ford is going to deny anything is wrong with them. The issue is usually once they're warmed up it goes away. Add to that, it's tricky to catch on a cylinder contribution test, which is what they're going to do to inspect them. They'll more than likely just string you along and tell you there's nothing wrong right until warranty runs out, then all of a sudden they're going to want to replace a bunch of them.
It also wouldn't hurt to have your batteries load tested and your FICM tested as well, the test procedure can be found at the top of the 6.0 page. Welcome to DB!
Old Dec 9, 2012 | 04:58 PM
bigred91's Avatar
It does go away when it's warm, and I'm only going to get it done because with the warranty it will only cost $100 for new ones. But if they won't then I'm going to try the rev x. But I'm not sure on oil or filter because I just let ford do it so that they still accept my warranty. And I have brand new batteries and just had my ficm checked an it's healthy. But thanks for the help!
Old Dec 10, 2012 | 07:18 AM
Mdub707's Avatar
Sounds good. I know, I went through all of the warranty battles too, what a waste of my life. I had one injector so bad that on stock tuning it would blow blue smoke out the exhaust under WOT. They still never replaced it. They kept my truck for a month once when I brought it in for sticky injectors, and all they did was clean my EGR valve and still had the audacity to charge me the $100 warranty deductible.
Buy the rev-x and save yourself the headache. If it's REALLY bad, it'll still show up.
Old Dec 11, 2012 | 09:39 PM
bigred91's Avatar
I dropped it off last night and they Are checking it this morning. If they don't warranty it I'm gonna be pissed. But they don't really care anyways, they will lose me, my friends and family as customers cause I am in school to be a diesel mechanic right now and can do this all myself anyways. I'll most likely just order some rev - x. Thanks for the help again!
Got a call today from the dealership, one injector is gone but the rest are fine and they are covering it. They are also hooking my y pipe up correctly from when I did my egr delete and didn't put it back on properly
Old Dec 12, 2012 | 12:03 PM
Mdub707's Avatar
Nice! Hopefully it fixes your problems.
Old Dec 31, 2012 | 12:22 AM
TheRobenator's Avatar
Update: They warrantied it ANd they even fixed his exhaust leak from the turbo! He did an EGR delete at my shop and we were too lazy to fix the exhaust leak, they fixed it for free and didn't say a word about the tune or egr not being there! woohoo!
Old Jan 1, 2013 | 10:11 AM
bigred91's Avatar
We cracked my y pipe doing my egr delete apparently and the dealership replaced it without me saying anything about it! And they gave me the old one, it's cracked on one of the expansion joints, not the mesh one but the other one and I was told I could fix it. Any ideas how?
Renteria1217
19
Oct 13, 2015 01:36 AM
Militant83
For Sale
Mar 18, 2015 03:34 PM
klein444
Mar 8, 2015 11:42 AM
nate379
For Sale
Feb 15, 2015 03:23 PM
nate379
For Sale
Feb 9, 2015 08:27 PM
