how to get good fuel milleage
Old Dec 8, 2012 | 09:35 PM
duckslayer31's Avatar
Default how to get good fuel milleage
ive got a 99 cummins ext cab long box. its lifted 4 inches on 35s it has the 3:55 rear end. stock transmission. what upgrades could i do to get better fuel mileage. ive hurd tuners, bigger exhaust, injectors. not sure what to look for help me out if u can. thanks
Old Dec 8, 2012 | 09:47 PM
Bryce's Avatar
First is to put a good lift pump on (fass, airdog, raptor) and a fuel pressure gauge then you can think about a tuner.
Old Dec 8, 2012 | 10:25 PM
lauber_03's Avatar
ya for sure good lp first then perhaps gauges after that intake/exhaust then tuner. thats how i did it atleast i just did a 1900 mile trip and averaged 23.4 mpg doing 75-80 so im happy with that.
Old Dec 9, 2012 | 01:13 AM
Ramitt's Avatar
If you dont have a lift pump and gauges do it asap! Sounds like you have a auto in which case is good up to a few hp(around 60-70hp). You can run a full tuner on your truck(edge,quad ect) on a stock tranny but dont expect to be hard on it and for it to last forever. Once the tranny is built right then intake,exhaust,good tuner,small injectors will benefit you with a few mpgs. Your auto will have your mpgs lower and your 4in lift and 35's arent helping either. Im getting about 16mpg in town and 21highway im a 6 speed tho and 4.10's with 33's and leveling kit. I usually run with my edge on level 5 if I keep my foot out of it that usually results in the best mpg.
Old Dec 9, 2012 | 01:49 AM
Dunright mobile's Avatar
Im new to this to. And i got to know. Why is a fuel gauge so important to mpgs? Isnt the fuel pressure going to be what its going to be regaurdless?
Old Dec 9, 2012 | 02:00 AM
Ramitt's Avatar
Actually poor fuel psi will cause bad mpgs believe it or not. The reason why fuel pressure gauges are so important on these trucks is cause poor psi will kill the injection pump then you are looking at about 1,300.00 to replace it. You need to ditch the stock lift pump even if you dont plan to mod the truck at all. Good psi will keep the injection pump cool and also the fuel helps keep it lubricated. Either way gauges help you tell whats going on with your truck(fuel psi,boost,egt's and tranny temp if your a auto)
Old Dec 9, 2012 | 02:14 AM
Ok thank u for clearing that up. Its a precaution or a saftey. Where can i get a fairly nice set up with all thos , on the pilar by the door is wher id like them
Old Dec 9, 2012 | 02:29 AM
Ramitt's Avatar
Usually I buy stuff from dap(dieselautopower.com) they most of the time have a good price. I would go around to a couple different sites and compare prices. You might be able to find some Christmas deals going on right now. Oh and STAY AWAY FROM ANYTHING GLOWSHIFT!
Old Dec 9, 2012 | 04:08 PM
Bryce's Avatar
A pessure gauge will also let you know when its time to change the fuel filter. At the top of the page go to Armory and click on price quote. Start a new thread with what you would like a price on and the db sponsors will give you a price.
Old Dec 9, 2012 | 04:12 PM
chadcycle 2500's Avatar
I heard some people had trouble with glow shift gauges,mine have worked fine for 2 yrs they have been in
