Diesel Fuel Tank Fittings
Old Mar 18, 2008 | 04:03 PM
cumminscanuck's Avatar
Default Diesel Fuel Tank Fittings
Can somebody tell me what kind of fitting is used to connect the return line to the diesel tank on my second gen. please? An explanation of how to remove it (remember it's out of sight) would also be appreciated.
Old Mar 18, 2008 | 04:38 PM
DangerousDuramax's Avatar
It uses the 3/8 "spring lock" fittings. Go to your local automotive store and pick up the fuel and A/C spring lock tool.
Old Mar 18, 2008 | 04:59 PM
Wyatt Earp's Avatar
The fitting comes apart with your hands. You need to press down and pull out in a single motion and it will come off.
The tool helps but it isn't needed 100%.
Old Mar 18, 2008 | 05:16 PM
Uncle Bubba's Avatar
Mine came lose pretty easy with a knife. Them factory fittings are a pain in the backside and notorious for going bad. I never have figured out how to get them apart in one piece.
Old Mar 18, 2008 | 06:09 PM
Whit's Avatar
Site Mascot
I have a pic of this hang on I will go find it
Old Mar 18, 2008 | 06:12 PM
Whit's Avatar
Site Mascot
The first step in this process is to disconnect the existing fuel line connected to the fuel tank pickup tube; this can be a challenge if you have never done it before as most of the work is done by feel since you cannot see the actual tank module, I have found 2 different ways to get to the feed line pickup, first is to lay under the truck and reach up and on top of the tank you will feel it or if your truck isn’t equipped with wheel well liners then you can go in from inside the wheel well, if you choose this method it will be easier to remove the left rear wheel and support the truck with a rated jack stand for safety. The line you are after is the one toward the rear of the truck as you can see in this picture, notice how the blue retention clip is inside the plastic fuel line connector. The trick here is to squeeze the two tabs together as to release the clip from the shoulders of the pickup tube inlet, squeeze and pull the connector off, the blue retention clip will stay with the pickup tube inlet , then you simply pull the retention clip one side at a time towards you till it actually inverts itself, do this to both halves of the clip and it will slide right off.
Old Mar 18, 2008 | 07:34 PM
That is precisly the information I wanted, thank you. One more question, when the blue clip is removed is the spigot on the tank unit suitable for attaching a 3/8 fuel line using a hose clamp?
Old Mar 18, 2008 | 08:50 PM
Whit's Avatar
Site Mascot
yes......slide er on there and put 2 clamps on it
Old Mar 18, 2008 | 09:07 PM
You just made my day. I've spent the last ten days converting this truck to run on waste veg.oil. The fuel return was the LAST job, wouldn't you know it would be a problem Tomorrow I will pick up some extra fuel line and "git er dun"
Thanks again
Old Mar 18, 2008 | 09:50 PM
Whit's Avatar
Site Mascot
any time bud...............its fun and I love it
