1997 F350 Problems... Any Advice?
Old Dec 7, 2012 | 11:25 AM
chwood's Avatar
Default 1997 F350 Problems... Any Advice?
Hey so I just bought a 97 f350 7.3 turbo dually with a flat bed with 99k miles on the truck. It has been sitting around for a while and the ABS light keeps blinking on the dash, also the truck wont start without spraying some starter fluid into the air filter, another this i wanted to ask is that it came with a steel flat bed, but i want to sell it and was wonder what a good price would be for a cleaned up painted flat bed. also did know if anyone had any advice on the problems i have been having.
p.s. i replaced the fuel filter and the air filter.
Old Dec 7, 2012 | 11:59 AM
1999stroker's Avatar
First off dont use ether man. A good flat bed could be wprth upwards of 1000 easy
Old Dec 7, 2012 | 01:45 PM
harley69's Avatar
what does it do when cranking do you wait up to a min to 2 min when WTS light shut off try that i dont know how cold it has been for you i have had this problem two when it was about 45 and below i replaced the glow plug relay and it has helped quite a bit it still rough at time but not as bad as before next ill replace glow plugs and valve cover gasket and harnes
Old Dec 7, 2012 | 01:54 PM
chwood's Avatar
thanks guys i appreciate the help, and i was going to do 1000 but i just wanted to check first.
also why shouldn't i use ether? will it cause more problems? and its been roughly 35 where i live so i usually wait about a minute after the WTS light goes out, but ill look into the glow plug relay.
thanks for the help guys if there is any other info or advice you may have on the truck let me know if you would.
Old Dec 7, 2012 | 01:57 PM
harley69's Avatar
im not quite sure what either does but the engine for some reason become dependent on the ether some one who probly explain it better
Old Dec 7, 2012 | 06:32 PM
cummins bronco's Avatar
if the ABS light is on and the speedo ever fluctuates it is probably the speed sensor on top of the rear diff. swap it out and the light should go out.
Old Dec 7, 2012 | 08:33 PM
twinboys's Avatar
Obviously your glow plugs are not working. If they were, the truck would start. Also, if they were working and you used ether, You would learn why not to use it and never forget.
Old Dec 7, 2012 | 09:13 PM
chwood's Avatar
thanks for being polite about there guy
Old Dec 7, 2012 | 11:27 PM
harley69's Avatar
My advice type is go to Google type in why you shouldn't. Use starting fluid in a engine with glow plugs look at video and the pics
Treeman69
94-98 7.3L Performance
8
Aug 20, 2015 06:43 PM
Msc
Apr 23, 2015 06:21 PM
Lewey Marcucci
Apr 4, 2015 10:18 PM
Wildcard
Sep 30, 2014 08:05 PM
angies04
Sep 29, 2014 04:11 PM
