dually tire help
Old Dec 7, 2012 | 10:36 AM
dill0007's Avatar
Default dually tire help
well i am in need of a little help. What is the largest tire that can be used on a dually without spacers? or should i just ask if 255/85/16 will fit without spacers cuz i just ordered them yesterday. i have been reading mixed reviews as to weather they will rub. i run empty most of the time. if i have to use a spacer can i just use a 1/4 or 1/2 inch or is there a reason that i would have to use the 1 1/2 or 2inch spacers. any help will be great cuz they will be here tuesday.
Old Dec 7, 2012 | 02:56 PM
tiremann9669's Avatar
Yo could go up to 285's your 255's wont be a problem
Old Dec 7, 2012 | 05:11 PM
dill0007's Avatar
how do you fit 2 tires that are almost 12 inchs wide without rubbing when the 245/75/16 that are 9.6 inches wide only clear by almost an inch? I don't want to have to run spacers if that is the way you fit the 285's.
Old Dec 9, 2012 | 01:05 AM
Ramitt's Avatar
285's will rub if they dont they will be really close and if you put a load on the truck they will def rub. 255/85's will be fine.
Old Dec 9, 2012 | 11:26 PM
I didn't mean to say 285's meant to say 265's
cummins.1.5.3.6.2.4
Sep 20, 2015 01:47 AM
dallasca
28
May 26, 2015 12:58 AM
salty4life
Apr 12, 2015 08:31 PM
LB7yooper
Chevy/GMC Duramax 01-04 LB7
Mar 23, 2015 11:33 AM
veggyoilkid
Tire, Wheel & Suspension
Nov 5, 2014 01:34 PM
