Lift pump question.
Old Dec 6, 2012 | 05:28 PM
smokincummins92's Avatar
Default Lift pump question.
I was in O'reilly's the other day and saw that they have a small diesel lift pump that might be 5 or 6psi. Its about $60 do yall think it would help the stock Carter pump on my truck?
Old Dec 6, 2012 | 05:48 PM
H.R.D's Avatar
Not worth it, get a good aftermarket LP. Save your self $1000 dollars later by spending $500 now.
Old Dec 6, 2012 | 05:52 PM
RAW's Avatar
RAW
X2 on doing it right. I put a block mounted on to run with my failing in tank pump when I first got he truck. 32psi at idle (WAY too much), 18 cruising, and 6 to 8 or so at WOT. It got me home, and was replaced with a FASS150 shortly. I wouldn't be surprised if that 32psi damaged the internals of my VP44.
Old Dec 6, 2012 | 05:56 PM
chadcycle 2500's Avatar
NO! at a mininum I would put on a fass ddrp that will outperform the stock lift pump,there is a fine screen to cleaned on the input side of the pump,a bit of a pain,There are other options,a much bigger fass,airdog,raptor,etc.You do not want 5-6 lbs fuel pressure on these trucks you want more! nothing under 10psi@ wide open throttle.If your going to do other mods to the truck go with a bigger pump. Put gauges on also pryo,lift pump pressure,boost, then go from there
Old Dec 6, 2012 | 08:38 PM
Yea the FASS DDRP is the pump I am going to get when the cash is available. I was just looking something cheaper I might could use just to help the stock pump last as long as possible. Ill just save the $60 and wait till I can afford the FASS pump. Thanks guys!!!
Old Dec 7, 2012 | 12:57 AM
Ramitt's Avatar
Like others have said 10psi at minimum. If you plan on doing any mods in the future you will want more than the ddrp. Its just a stock replacement for stock trucks.
Old Dec 7, 2012 | 11:09 AM
FASSAshley's Avatar
I would recommend the DDRP for a stock truck with no programmers or chips. We did actually do away with the banjo bolt screen and went with a small in line filter. Let us know if you need anything.
Old Dec 19, 2012 | 12:51 PM
Thanks I will! We installed a DDRP on my uncles 2001 dodge back in april and its been great! He has a BANKS tuner on it and it still holds great fuel pressure, he loves it!
Old Dec 24, 2012 | 11:24 AM
98dodgecummins's Avatar
what i recommend is the raptor frrp its a 100 gph and its only 300 dollars new and it mounts directly in the factory location. thats your best bet.
landon025
Sep 8, 2015 09:21 PM
PA 24valve
Aug 31, 2015 06:08 AM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
CJJD4640
9
Feb 9, 2015 07:22 AM
