Alternate Oil Pressure Sensor Location??
Old Dec 6, 2012 | 07:46 AM
SupaDave's Avatar
Default Alternate Oil Pressure Sensor Location??
Installing new Edge Insight Digital Gauge system (gauges only, no juice, no attitude) 0n my 2nd gen 24V.
The OBD for this model year does not pick up oil pressure so I ordered an additional pressure sensor along with their universal accessory set-up.
My question is: Is there an alternate port location I can take oil pressure readings off, without removing and disabling my factory gauge? And where is it located?
Thanx,
SD
Old Dec 6, 2012 | 07:49 AM
RAW's Avatar
RAW
I am very surprised you can't get oil pressure on the Insight. I can on my EJWA.
There is a second port on the top of your oil filter housing you could run a pressure sender off of. It is 1/8" NPT thread.
Old Dec 6, 2012 | 07:52 AM
SupaDave's Avatar
Thanx RA
Yea, guess thats one of the differences between the 1998 and 2001 OBD's
Old Dec 6, 2012 | 08:56 AM
RAW's Avatar
RAW
Should still be able to read it if it's a 24 valve Cummins. I have no idea why it wouldn't. Have you confirmed it with Edge that it can't be done?
Old Dec 6, 2012 | 11:31 AM
SupaDave's Avatar
RA-
Off Edge Website:
*Click application below to view vehicle specific parameters (PIDs).
**These are parameters for the Insight, Evolution, and Juice with Attitude CS and CTS products.
Dodge 1998.5-1999 24V 5.9L Cummins
Accel Pedal Position, Battery Temp, Battery Voltage, Boost, Calculated Load, Corrected Speed, Engine Coolant Temp, Engine Speed, Fuel Level, Fuel Pressure (Juice w/ Attitude Only), Gear, Intake Air Temp, Throttle Position, Time 0-60, Time 1/4 mile, Trans Temp, Vehicle Speed (Mileage Coach Not Yet Available)
Dave
Old Dec 6, 2012 | 04:38 PM
RAW's Avatar
RAW
Oil pressure, and other parameters, must come off the CAN connector under the hood for the EJWA.
Old Dec 6, 2012 | 05:00 PM
SupaDave's Avatar
Got er in..........
workin great so far.
Thanx for the help, RA.
Old Dec 6, 2012 | 05:02 PM
RAW's Avatar
RAW
Ni problem, glad you have it working.
Durtyd09
Nov 11, 2015 01:43 PM
purnell82
Jul 22, 2015 10:42 AM
jhprice
Mar 29, 2015 09:36 PM
powerstroke4178
Nov 27, 2014 02:35 PM
Jeremy Babb
Chevy/GMC Duramax 01-04 LB7
13
Oct 1, 2014 06:27 AM
