any fix to a injection pump on a 95 6.5
Old Dec 5, 2012 | 08:47 PM
Jason Clifford's Avatar
Default any fix to a injection pump on a 95 6.5
i took my truck to chevy and they said i need a new injection pump on my truck its a 95 6.5 its going to coast 2200 to fix it and i dont have it is there any easy fix to this without replacing it
Old Dec 6, 2012 | 01:28 AM
cviola2005's Avatar
not really. but if you have any mechanical skills, you could buy an injection pump for around $800 to $1200 and do it yourself
Old Dec 7, 2012 | 04:52 AM
racer55's Avatar
What are the symptoms?
It might not be the IP at all,it just pays the mechanic more to replace it than fix the real problem sometimes.
Old Dec 8, 2012 | 02:23 AM
cviola2005's Avatar
What kind of problems are you having?
True. Happens alot, I'm sure.
Old Dec 8, 2012 | 09:47 AM
chrisa1995's Avatar
I agree give us some symptoms! lets see if you can save some money.
Old Dec 8, 2012 | 04:42 PM
Turbine Doc's Avatar
Many "bad IPs" are just a bad driver which are separate from the IP but mounted on it, need more info like codes & symptoms of what is happening, I've fixed a number of "bad IPs" myself with cleaning of GND lug on back of the pass side head which is the common electronics control gnd
Dbleo351
Nov 20, 2016 09:34 AM
moneypitk5
Feb 12, 2015 11:01 AM
airspeed181
Jan 19, 2015 09:00 PM
letters4and18
Dec 11, 2014 12:03 PM
rtbcoop
Nov 29, 2014 11:33 PM
