New cummins. Got some ideas. Need input
Old Dec 5, 2012 | 08:28 PM
Cowboy_Cadillac's Avatar
Default New cummins. Got some ideas. Need input
Ok so I just bought I 01 2500. I've only ever messed with 6.0 powerstroke so I need Ideas. I've got around 1500$ to play with. I'm thinking a quadzilla with adrenaline, boost fooler and some sort of intake and maybe some larger injectors. Any thoughts fellas?? I'd like to get as muchmuch power as I can without risking my tranny before I have the money to upgrade.
Old Dec 5, 2012 | 08:42 PM
BarryB's Avatar
lift pump, and gauges, or a box that has the gauges built in. Then start added the other stuff. I personally would add the other stuff until after you have the tranny built. JMHO.
Old Dec 5, 2012 | 09:18 PM
RAW's Avatar
RAW
A good lift pump, quad adren, exhaust, and BHAF will eat up that $1500 and give you a significant difference in the truck.
Old Dec 5, 2012 | 11:32 PM
blacksally's Avatar
GO BIG OR GO HOME........!
Old Dec 6, 2012 | 02:51 PM
1AMatt's Avatar
Site Sponsor - 1aauto
Lift pump, guages, trans first... Then you can start playin
Old Dec 6, 2012 | 02:58 PM
GuyWithA24Valve's Avatar
If you don't do anything to the tranny, you at least HAVE to do an aftermarket lift pump
Old Dec 7, 2012 | 01:03 AM
Ramitt's Avatar
Gauges and lift pump before anything else. You auto or manual? The autos can only hold so much power for so long after being hard on them. Same goes for the stock clutch on manuals.
Old Dec 8, 2012 | 04:51 PM
MBFD 592's Avatar
aftermarket lift pump to protect your injection pump
Old Dec 8, 2012 | 07:24 PM
jkidd1's Avatar
do exhaust when you change out for bigger turbo or injectors. not much to gain there except noise. you can spend $200-300 on better mods at this stage. The stock turbo is such a huge restriction there is no real need to talk about change in exhaust.
Shun70
Diesel Engine Conversions
Jun 1, 2026 05:02 AM
RedChevy44
Apr 21, 2015 05:47 AM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
